arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 24d Gender: Male Location: Perth Posted 27/04/18 03:42 PM Share Posted 27/04/18 03:42 PM Only use corrugated hose in the cradle. And clamps. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 29d Gender: Male Location: Canberra ACT Posted 27/04/18 09:26 PM Share Posted 27/04/18 09:26 PM Thanks for that. Why the corrugated? Just to help set the depth correctly without kinking a normal hose when installing, or a longer term reason? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 29d Gender: Male Location: Canberra ACT Posted 27/04/18 09:45 PM Share Posted 27/04/18 09:45 PM Actually ignore me. Did some more research and I think I will loop some hose and if that turns out to be too difficult to work with, I'll order these:https://www.efihardware.com/products/2524/Submersible-Flex-Fuel-Hose-E85-Compatible-150mm-Long Link to comment Share on other sites More sharing options...
Hirdy Member 31 Member For: 5y 11m 1d Posted 05/12/18 04:21 PM Share Posted 05/12/18 04:21 PM Has Anyone installed a Walbro 460lph pump like this as I have it at home and will be doing it this Saturday, Any tips peeps can give please? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 05/12/18 10:04 PM Share Posted 05/12/18 10:04 PM it's a quite similar process, just more of a squeeze to fit it in. You'll be fine following the instructions in this thread. Link to comment Share on other sites More sharing options...
Parker411 New Member 5 Member For: 5y 1m 3d Posted 17/03/19 05:45 AM Share Posted 17/03/19 05:45 AM Could anyone help me with some more detail on removing that round plastic cover under the seat, please? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 17/03/19 05:48 AM Share Posted 17/03/19 05:48 AM it's just a bunch of screws around the edge of the circle mount. for the fuel lines, there's a bit of finessing with where you apply the pressure (a pick set is a very valuable tool to use for those connectors) to get them off the 3 fuel line connections (make sure to re-connect them in the same order, e.g. mark which is which). if you mean the bit of grey plastic over the top of the whole thing, just un-plug the obviously removable bit and then lever under the edges with a flat-head and pull upwards to remove it 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 22d Gender: Male Location: South Australia Posted 17/03/19 05:56 AM Share Posted 17/03/19 05:56 AM Step one: Try to rip it out with your fingers for five minutes, then give up in frustration. Step two: Lever it with a screwdriver. 2 Link to comment Share on other sites More sharing options...
Parker411 New Member 5 Member For: 5y 1m 3d Posted 17/03/19 05:59 AM Share Posted 17/03/19 05:59 AM Thanks guys - just didn't want to destroy it or the sheet metal of the floor, and it has a little arrow on it, so wondered if it unscrewed or something. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 22d Gender: Male Location: South Australia Posted 17/03/19 06:01 AM Share Posted 17/03/19 06:01 AM It just pops out. 1 Link to comment Share on other sites More sharing options...
