f6rspec Banned 124 Member For: 15y 10m 5d Gender: Male Location: perth Posted 30/03/09 04:00 AM Share Posted 30/03/09 04:00 AM Danny Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 18y 4m 24d Gender: Male Location: Melbourne Posted 30/03/09 07:37 AM Share Posted 30/03/09 07:37 AM Hence why people are scared of him. He knows too much! lol Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 3m 9d Gender: Male Location: QLD Posted 31/03/09 08:00 AM Share Posted 31/03/09 08:00 AM Thanks Danny you are a great help, switched off min / max values.I have run the settings you have suggested.Looks good Idle WOT seems a little slow to get to low 12s.Yes I have just been watching the PLX Wideband AFR/Lambda gauge forreadings so far.Will have to do some data logging to check all you have mentioned.Did 3 runs at the drags Saturday night with first run pinging in 3rd, got off itand back into it after I selected 4th, ran 12.902 at 116mph.Not bad concidering I was doing soft launch's 2.3's and being a manual.2nd run I gave it 4% Fuel at WOT and it didnt ping but surged in 4th.I was running 3/4 tank of fuel and found it to be odd.Did one last run and found it to do the same so that was it for the night.Fuel AFR was 12.2 WOT everyrun with no leans while WOT.also noticed on the way out it would be sitting on 14.6 to 15.2 then all of a sudden itwould start running high 11 to mid 12's. thinking that Boost sensor to the wastegatemaybe causing these issues, due to its ticking sound I have told yous about.Its not a gauge issue as the instant fuel mileage also corresponds to it.When it was running 14.6 to 15.2's I was getting 6.8 litres to the 100 then when it changedit climbed to 14 litre's per 100k.Also pulled out and over took a vehicle on the way out while running 11 to 12 AFR'sand it pinged. turn aircond off wound down window and tested for pinging again and notonce, the AFR had also returned to 14.6 to 15.2 AFR.Thinking that what ever maybe causing it may be the reason of the AFR's changing and theproblem from the track.I checked for any fault codes and nothing there. Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 18y 9m 15d Gender: Male Location: OZ Posted 31/03/09 12:54 PM Share Posted 31/03/09 12:54 PM ......drags I like your enthusiasm lol. What is your open loop delay blending ramp set to? Factory is 0.025, you will need to increase this to get a faster transition to open loop control. Link to comment Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 21y 3m 17d Gender: Male Location: Not sure? Posted 31/03/09 06:55 PM Share Posted 31/03/09 06:55 PM My head hurts. Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 3m 9d Gender: Male Location: QLD Posted 01/04/09 04:35 AM Share Posted 01/04/09 04:35 AM Your telling me, I will have a look when I get home.Think I have find the reason behind the AFR's moving around, think it is all because ofthe Boost control solinoid.It basically started clicking when I did the change of the Plenum, pipe work, IC & Deka's.Rechecked for any fault codes and still nothing there. Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 18y 9m 15d Gender: Male Location: OZ Posted 01/04/09 05:14 AM Share Posted 01/04/09 05:14 AM Solenoid clicking is common, I suspect a deeper problem. It could be a number of things. You said you surged in 4th with 3/4 tank.......1/3 tank I'd say that's ok but this seems odd also. As Danny mentioned earlier check fuel pressure, you may have a greater fuelling issue. Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 18y 8m 12d Gender: Male Location: Melb Posted 01/04/09 05:30 AM Author Share Posted 01/04/09 05:30 AM (edited) Question, regarding moving around AFR's..Have you disabled the flange/turbo/cat over temp fueling?I bet you havent =)And I bet you have a fuel system issue.. When I get back to melbourne, I'll get you to email me your tune file, and I'll see whats going on.. Edited 01/04/09 05:39 AM by Headsex Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 3m 9d Gender: Male Location: QLD Posted 01/04/09 08:53 AM Share Posted 01/04/09 08:53 AM ......drags I like your enthusiasm lol. What is your open loop delay blending ramp set to? Factory is 0.025, you will need to increase this to get a faster transition to open loop control.Its set to 0.500DannyI have only found This under Engine Temp Limits / Exhaust Temp / Exhaust Flange TempLoad @ 500rpm0.200 - 750.00.400 - 920.00.600 - 1100.00.800 - 1170.01.000 - 1255.01.400 - 1275.0Load @ 2000rpm0.200 - 1200.00.400 - 1340.00.600 - 1400.00.800 - 1440.01.000 - 1540.01.400 - 1650.0Load @ 3000rpm0.200 - 1280.00.400 - 1430.00.600 - 1540.00.800 - 1630.01.000 - 1660.31.400 - 1780.0Load @ 4000rpm0.200 - 1400.00.400 - 1510.00.600 - 1645.00.800 - 1670.01.000 - 1700.01.400 - 1790.0Load @ 5000rpm0.200 - 1450.00.400 - 1590.00.600 - 1660.00.800 - 1730.01.000 - 1800.01.400 - 1880.0Load @ 6000rpm0.200 - 1448.00.400 - 1560.00.600 - 1690.00.800 - 1800.01.000 - 1870.01.400 - 1910.0Also Think I may have been running more boost down the trackas I set the wastegate to 100% instead of 90% where I usuallyhave it set.Noticed on the way home when I gave it a squirt in 3rdmandn pulledapprox 5 lengths on my brothers FG XR6Turbo, boost went to 20psi.Maybe the Fuel pump letting it down at that boost.Everytime today When I WOT it, it ran clean and 12.1 AFR, mineyou it wasn't from stand still through to 4th gear.Thinking Fuel pump may not have the flow needed.I will be fitting a surge tank and 044 pump next up.This running at good afrs then going very rich is odd.It just does it randomly back and forth, eg say drive on 80k road stop at lights itsreading 14.6's then next set pull up it is reading 11.9's, it does it while cruisingalso. I think when I give it some WOT it returns good for a while then back rich.So maybe some sort of Airflow, fuel temp setting adjusting it to rich due to themods done.had a look at my generic 10psi tune compared with my 12psi generic and there islots of differances.This tells me I must need to make more adjustments to bring my original12psi with the Deka injector up to a correct setup.It would be good if there was descriptions for all settings in Advantage3 or the manual.It just might make things understandable a little at least.Will send my tune file for you to check over whenever you are ready danny.Just dont let any of my secrets out or we may have lots of others carsrunning risky like mine LOL. Link to comment Share on other sites More sharing options...
STICKS Member 90 Member For: 15y 5m 4d Posted 05/04/09 12:02 PM Share Posted 05/04/09 12:02 PM lol danny put a wolf on it ford ecu's are cactus Link to comment Share on other sites More sharing options...
