Azid Member 213 Member For: 12y 6m 10d Posted 01/02/12 02:40 AM Share Posted 01/02/12 02:40 AM Is there any knack to putting the dash back in? As you have to be but rough to get it out do u have to be rough to put back in or just line up with steel clips and push it forward? Link to comment Share on other sites More sharing options...
*Sloxr6* Member 81 Member For: 13y 9m 23d Posted 01/02/12 04:14 AM Share Posted 01/02/12 04:14 AM Bookmarked. Thanks mate will help me out when I finally get off my arse and pull mine out.Did you try and disconnect the battery again and leave it off for a few minutes then reconnect? I had to do that with mine. Couldn't get the damn thing to go past the code on the icc. I tried everything I was spitting the dummy big time. Worked fine when I reconneted the battery the second time though. Link to comment Share on other sites More sharing options...
bassy Member 9 Member For: 13y 5m 16d Posted 19/03/12 11:32 AM Share Posted 19/03/12 11:32 AM Would I have to follow this to take my dash out just for the air mix shaft ? im pretty sure my air mix shaft has broken and im unsure weather do I take out the centre console or do I take out the whole dash ?? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 19/03/12 12:06 PM Share Posted 19/03/12 12:06 PM do you have to do this if you want to install gauges? theres no easier way? hha looks like a nightmareNah mate, I didnt even take the ICC out when I fitted a triple set. Just NEVER run mechanical oil pressure inside the car. The only mechanical gauge to run is boost. Link to comment Share on other sites More sharing options...
SHO-247 Member 77 Member For: 13y 5m 19d Gender: Male Location: South Australia Posted 12/06/12 08:22 AM Share Posted 12/06/12 08:22 AM how long can you have the car unplugged befor you need to go to ford? Link to comment Share on other sites More sharing options...
Detonator1 Member 44 Member For: 18y 6d Gender: Male Location: Brisbane, Queensland Posted 13/06/12 05:04 AM Share Posted 13/06/12 05:04 AM Dont think you will have any problems, when my engine was being rebuilt I had the car unplugged from a battery for 2 years. When I put it back in to get on the tow truck the key still turned the ICC back on and had full radio functionality. Car has been running fine ever since, no trips to ford! 1 Link to comment Share on other sites More sharing options...
shai12 Inactive Members 1 Member For: 16y 4m 28d Posted 22/09/12 06:58 AM Share Posted 22/09/12 06:58 AM thanks for the tutorial 1 Link to comment Share on other sites More sharing options...
Mike007 New Member 8 Member For: 11y 3m 14d Posted 20/12/12 12:55 PM Share Posted 20/12/12 12:55 PM Does anyone have the same info but for a FG? Please help Link to comment Share on other sites More sharing options...
rockafellqeinstien Member 325 Member For: 15y 8m 5d Posted 20/02/13 11:06 PM Share Posted 20/02/13 11:06 PM just a foillow up on whether any one has done this for an FG - I figure its got to be close Link to comment Share on other sites More sharing options...
WARHUNTO Member 3 Member For: 10y 10m 6d Posted 23/05/13 01:25 PM Share Posted 23/05/13 01:25 PM Hey guys, changed the air mixer shaft today, now its back together the car wont start.indicators dont work but cluster illuminates, tail lights work, interior light works, central locking ok, icc comes up security code error.I was sure I plugged everything back in correctly but obviously I didnt.Can anybody point me in the right direction as to where I should start working back from?Cheers. Link to comment Share on other sites More sharing options...
