Erko Donating Members 1,079 Member For: 20y 6m 22d Gender: Male Location: Sydney Posted 31/01/09 04:13 AM Author Share Posted 31/01/09 04:13 AM Shock AbsorbersGenerally, Ford OEM shocks are well past their best by around 40,000klms. The thing is you may not notice due to the gradual way they wear out. Without putting them on a shock dyno you can often tell if you pay attention to the rebound when hitting bumps on corners, you get a skipping / skating tendency as the tyre is not “glued” to the road like it should be, rather its in the air as the worn shock doesn’t rebound fast enough.In addition to the Monroe and Pedders type OEM replacement shocks, there are 2 main shock types that will give your car better than new ride and handling. Reason being, both of these are far better than the $10 per corner Ford allows when building your car. Bilstein Sport – (Yellow and Blue) direct replacement non adjustable shocks. Works well with stock or King Springs. Significantly better damping and control than stock. Refer member aiboart’s review at http://www.fordxr6turbo.com/forum/index.ph...&hl=aiboartYou can expect 100,000klms or so out of the Bilsteins. Bilsteins are rebuildable. Koni – Koni makes both adjustable (Yellow) and Non Adjustable (Red) for the B series. The Yellow dampers are rebound adjustable on the car from the top of the shock. The adjustment is mostly to cater for wear as the shock ages. The Red shocks are designed as an OEM replacement “fit and forget” and are not adjustable. Both Yellow and Red will provide many years of service with significantly improved performance over stock. 1 Link to comment Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 20y 6m 22d Gender: Male Location: Sydney Posted 02/02/09 09:28 PM Author Share Posted 02/02/09 09:28 PM BumpstopsWhen lowering the rear bump stops need attention. The two options are either cutting down the stock bumpstops ($ free), or installing shortened bumpstops available from Suppliers like Superpro. Installing shorter bumpstops is the preferred method - cost is in the $50-70 range. The reason shorter bumpstops are preferred is that when your car bottoms out the shorter stop is a lot more progressive which means that you will get less bounce and maintain better traction/grip on the road surface when compared to cut down bump stops. Standard bumpstops measure 90mm while the Superpro shorter bump stops measure 70mm. Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 20y 8m 18d Gender: Male Location: Newcastle Posted 03/02/09 09:54 AM Share Posted 03/02/09 09:54 AM Geez Erko spent some time doing this. Thanks for the time and info.Benny Link to comment Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 20y 6m 22d Gender: Male Location: Sydney Posted 03/02/09 10:12 AM Author Share Posted 03/02/09 10:12 AM no worries Benny, hope someone gets some use from it. Not done yet though, will be adding some more stuff and then it will be cleaned up. Link to comment Share on other sites More sharing options...
Pube Member 159 Member For: 16y 11m 11d Gender: Male Location: Sydney, NSW Posted 03/02/09 11:04 AM Share Posted 03/02/09 11:04 AM Shock AbsorbersKoni – Koni makes both adjustable (Yellow) and Non Adjustable (Red) for the B series. The Yellow dampers are rebound adjustable on the car from the top of the shock. The adjustment is mostly to cater for wear as the shock ages. The Red shocks are designed as an OEM replacement “fit and forget” and are not adjustable. Both Yellow and Red will provide many years of service with significantly improved performance over stock.Koni 'reds' are adjustable, just not on the car. You have to remove the shock from the car and adjust by fully compressing the shock until it clicks into something like an internal valve. Once the valve is located, the shiny part of the shock is rotated clockwise or anti-clockwise in the body for a harder/softer setting. Once you are happy, you can extend the shock and fit to car Link to comment Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 20y 6m 22d Gender: Male Location: Sydney Posted 03/02/09 08:38 PM Author Share Posted 03/02/09 08:38 PM Thanks Pube, noted..I wasnt aware of that. Will update thread later. Link to comment Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 20y 6m 22d Gender: Male Location: Sydney Posted 10/02/09 06:16 AM Author Share Posted 10/02/09 06:16 AM Wheel Width and OffsetStandard width is 8 inches and offset is +36. PCD is 5x114.3 (Same as Late model Mitsu Evos, Mazda RX-8, Some Nissans).Below Link is a good tool to work out how wheels that you are planning to use will work on your car - ie. a guide to whether they will fit or not.http://www.1010tires.com/WheelOffsetCalculator.asp The rear of the B Series has a fair bit of room, utes more so than sedans, however the front width is limited by the front suspension arm (look how much clearance you have stock - you might be surprised). Link to comment Share on other sites More sharing options...
octane6 Member 19 Member For: 15y 6m 22d Gender: Male Location: Wollongong Posted 25/04/09 08:40 AM Share Posted 25/04/09 08:40 AM Gdaydoes anyone have a part # for shorter rear bumpstops in kings??? Link to comment Share on other sites More sharing options...
Smoke them tyres Member 557 Member For: 16y 4m 2d Gender: Male Location: Brisbane Posted 06/05/09 12:48 PM Share Posted 06/05/09 12:48 PM Erko,Any chance of some "motion ratios" for the front and rear suspensions (particularly the front)? I need to do some work on some spring rates.....I already have some wheel rates in mind Link to comment Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 20y 6m 22d Gender: Male Location: Sydney Posted 07/05/09 02:42 AM Author Share Posted 07/05/09 02:42 AM sorry mate, I dont have that info. what spring rates are you thinking? Link to comment Share on other sites More sharing options...
