  • Cryptic Clothing Company
  • Member For: 17y 7d
how does the car run richer with a thermo?? I use a 77deg thermo in mine.. most other people use 82deg
  • 1 month later...
  • Member For: 17y 5m
The PCM does an emissions test once the car reaches a certain temperature, if you run too cold of a termo (unless you tune has been modified) the factory configuration will never reach it emissions self test and they do run slightly richer.
Factory thermo is around 190F, a 180-185F thermo will be more then sufficient.
