Aftermarket Oil Filter Adaptor
PHANTMXR6
  • 3 weeks later...
  • Member For: 16y 6m 10d
Not sure mate. What oil filter does the FG use?
I just bought a adaptor plate for my BF MKII Turbo (which I found has a different size thread to the BA ones) from Repco, Speco brand, Part#547-53 $40, and is quite good quality compared to others I have seen.
The Thread on the adaptor is M22x1.5mm Pitch. If your FG uses an AL101 filter (Same as the BF) then you should be right. Just make sure though that the shop you buy the filter from will accept it back if it doesnt fit. Probably best to buy a spare oil filter (You will use one eventually) and take it to the shop you intend to buy the sandwich plate from. That way you can matchup the thread and seal area, peice of P.
  • It's not a MKI!
  • Member For: 15y 9m 9d
I've got a brand new oil filter sitting in front of me. It says AFL 101.
Not as easy as just taking the filter in to the shop as I only have a Repco and Auto One store here and they both carry diddly squat.
Edited by PHANTMXR6
  • Forged Member
  • Member For: 17y 1m 21d
As mackie said mate, the BF uses the AFL101 oil filter, so if the FG uses the same - which it does - the BF adapter plate will work
My Bad, my bad, I ment to type AFL101, DOH!!
You know what its like,.. trying to type these fast little reply's before the boss walks in, lol
Is there also a AL101 filter? If there was, I can see how that would have confusha'd you!
  • It's not a MKI!
I have no idea, but thanks for the clarification.
Also, the Speco unit you advise using says it suits Ford V8, BA on.
You also said the BA was different to the BF.
Does this mean the number you posted earlier is correct for the AFL101 filter or does it suit the BA??
Just a bit confused at the moment and don't want to buy the wrong one.
LOL, Hairy muff
The Speco unit I mentioned earlier suits the AFL101 and is good for:
BA V8
BF XR6T
Possibly FG as senna_t mentioned earlier
All the above have a 22mm thread, whereas the BA 6's have a smaller 18mm thread. that's why the BA 6's use a different oil filter.
Hope its all clear as mud now.
