Azzman460 Azzman Member 223 Member For: 15y 8m 6d Gender: Male Location: Melbourne Posted 10/11/08 01:50 AM Share Posted 10/11/08 01:50 AM Hey guys, I am planning on taking out my engine and gearbox to replace them with a turbo engine and 6 speed manual gearbox. I was thinking I would like to take out the cluster and replace it with a FPV or even another XR cluster set on 0kms, so I have 2 seperate clusters with the correct amount of kms for each engine and gearbox.Does anybody know if its possible to set an old cluster to 0kms? I have a turbo PCM to replace the N/A PCM so the car will be getting re-flashed to work with the new turbo PCM so a new cluster could also be flashed with the car then. Any ideas? Link to comment Share on other sites More sharing options...
Guest Guests Posted 10/11/08 01:53 AM Share Posted 10/11/08 01:53 AM Is the engine going in brand new? If not, it's illegal to put a different cluster in AFAIK??You can't reset a BA/F cluster regardless. They can only be done before they hit 100km... Link to comment Share on other sites More sharing options...
Azzman460 Azzman Member 223 Member For: 15y 8m 6d Gender: Male Location: Melbourne Posted 10/11/08 03:37 AM Author Share Posted 10/11/08 03:37 AM well its going in fully rebuilt with new pistons and rods and all the other gear. So I would have to leave my original cluster in and there is no way around this? or I would have to do an inhale/exhale to my other cluster? Link to comment Share on other sites More sharing options...
Guest Guests Posted 10/11/08 04:00 AM Share Posted 10/11/08 04:00 AM Pretty sure it's illegal to put a new cluster in unless it's gonna display the same kms. Just because the pistons/rods are new, the block, crank, head etc aren't, either is the rest of the car. Link to comment Share on other sites More sharing options...
Tree Monkey Member 685 Member For: 16y 3m 20d Gender: Male Location: brisvagas / Manly Posted 10/11/08 06:46 AM Share Posted 10/11/08 06:46 AM (edited) It is illegal to alter the reading on a speedo, but it is not illegal to fit a speedo to a car that has less k's. e.g your car has 30000kms you put a cluster in with 12000k, this is legal. You can not legaly change a cluster's km reading. With the right program you can reset a cluster reading regardless of km's but, this again IS ILLEGAL. Edited 10/11/08 06:50 AM by Tree Monkey Link to comment Share on other sites More sharing options...
Azzman460 Azzman Member 223 Member For: 15y 8m 6d Gender: Male Location: Melbourne Posted 10/11/08 07:52 AM Author Share Posted 10/11/08 07:52 AM ok then, so I can just put this cluster in and go regardless of the kms? I have no intention of lying about the kms, its just so I can record how many kms each engine and gearbox has done.I May just do an inhale/exhale to the new cluster and keep the same amount of kms travelled for the entire car. On a seperate note, will a BA FPV GT cluster fit into a BF MKII ok without having and programming problems?? Link to comment Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 18y 9m 28d Gender: Male Location: Melbourne Posted 10/11/08 09:16 AM Share Posted 10/11/08 09:16 AM (edited) It is illegal to have change the odometer of a vehicle. Unless you are replacing, the body, chassis, brakes, suspension(pretty much a new car) then the odometer must stay the same. It is 100% legal to replace a cluster with the same odometer but not less than or greater.And it is actually legal to reset odometers on clusters, but it is illegal to install them into a car if its incorrect.I know for a fact that the BA/BF clusters can be altered as I can do it. I do not wind them back so dont ask. I normally alter FPV/XR clusters to suit the car they are going into etc. As for programming, Depends on what type of fpv it come out of, ute/sedan, also some BA's had a different ABS/Brake fail connection so it may not be compatible.Matt Edited 10/11/08 09:19 AM by ORSMBA Link to comment Share on other sites More sharing options...
Azzman460 Azzman Member 223 Member For: 15y 8m 6d Gender: Male Location: Melbourne Posted 10/11/08 09:47 AM Author Share Posted 10/11/08 09:47 AM So would I be able to do an inhale/exhale from my cluster to the secondhand FPV Cluster or would I have to do something different? That way the new cluster displays the exact same information as the old one.(for those of you that don't know, inhale/exhale is where you take all the info off your current cluster and put it all into a new cluster, so the scan tool inhales the info, then exhales it!)I'm just not sure if you can do this onto a used cluster form your current one, or only onto new clusters. Link to comment Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 18y 9m 28d Gender: Male Location: Melbourne Posted 10/11/08 09:51 AM Share Posted 10/11/08 09:51 AM Yes you can transfer the information over. Ford cant do it. but look below. Link to comment Share on other sites More sharing options...
Azzman460 Azzman Member 223 Member For: 15y 8m 6d Gender: Male Location: Melbourne Posted 10/11/08 09:55 AM Author Share Posted 10/11/08 09:55 AM haha very nice work, I like your style. So is it just an inhale/exhale? or am I correct in saying that this feature is only for brand new clusters? Link to comment Share on other sites More sharing options...
