XR06T Silver Donating Members 4,146 Member For: 18y 9m 5d Gender: Male Posted 27/10/08 04:00 AM Share Posted 27/10/08 04:00 AM perfect description there mate.tip: you will definatly need long sockets to get to the strut bolts in the engine bay! Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 16y 11m Gender: Male Location: central coast Posted 27/10/08 04:53 AM Author Share Posted 27/10/08 04:53 AM do you have a trick for the one under the ecu that was a pain Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 9m 5d Gender: Male Posted 27/10/08 05:17 AM Share Posted 27/10/08 05:17 AM we just used a long socket and an extension and it wasn't a drama! Link to comment Share on other sites More sharing options...
Guest Spinifex Guests Posted 24/12/08 08:07 AM Share Posted 24/12/08 08:07 AM (edited) Yesterday, my own Bilstiens arrived on my doorstep. In between the gazillion other bloody things I did today, I fitted the rear pair.Did the left side first and it was a bit of a pain in the bum, but what I learned, I put in to practice and did the right side in no time.Here`s a couple tips. Grab a second jack, okay I left my trolley jack under the car with a chassis stand as insurance, so I grabbed the weird scissor jack outa me Daewoo work car and supported the bottom control arm with it. Just crack the top retaining bolt, then remove the bottom bugger alltogether. Finally remove the top bolt and withdraw the stock shock.NOW!!! The Bilstein is a bee`s dick bigger at the top mount eye part. so, loosen the 10 mm head size bolts around the top eyelet - mount that are circled in the pic.Loosen them 3/4`s the way out.If you don`t, you`ll dick around for 30 or more mins trying to get the top bolt in. Loosen those four eyelet bracket bolts off and you are gold.Tighten it all up, before you put the wheel on, have a squizz at your rear brake pads. I wire brushed the rust off the hub where it mates up with the wheel and wiped on a bit of lanotec sheep grease in the vain hope it`d stop it from returning.After a quick drive, I felt a tangible difference just with the rears. My car would axle tramp like a dirty old HQ, but it does nothing of the kind now. I`m itching to fit the fronts for sure.. I reckon the stockers are shagged, you can just work them like a push bike pump almost, the Billy`s? ah nuh.. Edited 24/12/08 08:14 AM by Spinifex Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 9m 5d Gender: Male Posted 24/12/08 08:44 AM Share Posted 24/12/08 08:44 AM nice going mate.whats the damage on 4 bilsteins? Link to comment Share on other sites More sharing options...
Guest Spinifex Guests Posted 24/12/08 09:26 AM Share Posted 24/12/08 09:26 AM $1055 to my door. Ordered late last friday received here tuesday arvo, not too shabby so close to xmas.. I typed Bilstein AU into google and went from there.Can not wait to fit the fronts.. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 9m 5d Gender: Male Posted 24/12/08 10:51 AM Share Posted 24/12/08 10:51 AM cheers man, not a bad price!!!! Link to comment Share on other sites More sharing options...
Guest Spinifex Guests Posted 24/12/08 11:14 AM Share Posted 24/12/08 11:14 AM In relation to what you get out of it, I reckon its real value indeed. I can`t wait to put what I learned from the original post into practice and fit the fronts. Thanks our06t by the way.LOL, I reckon I`ll be under the front guards xmas arvo.. Link to comment Share on other sites More sharing options...
Guest Spinifex Guests Posted 27/12/08 02:15 AM Share Posted 27/12/08 02:15 AM LOL, how much to have the fronts fitted?? I`m mid way through this, just stopped for a turkey sanga.It`s a bit of a bastard by ya self, eh.Not impossible, but not much fun. Link to comment Share on other sites More sharing options...
Guest Spinifex Guests Posted 27/12/08 07:01 AM Share Posted 27/12/08 07:01 AM (edited) Okay I`d have editing my last but didn`t have time to work it out.I`ve replaced all four shocks on my BF Typhoon with Bilsteins.The stock springs remain, I`m happy to keep them there for now, I`ve got no real issue with them.Couple more clues I can add for the front fitting: If you`re gonna do one side at a time like I had too ( which is to say jack one side at a time cause of ya rabbit hole carport ) undo the end links for the front sway bar first, both of them. It becomes apparent that the bar won`t swing down outa the way and allow the bottom control arm to travel far enough to let the shock come out.Undo the middle - main nut on the top of the shock while its still in the car, just back it off a bit and it makes its easier to remove on the ground.Once you`re finished, go for a drive and be very happy with your purchase.I gained ride quality I beleive. It just feel waaaaay better everywhere.I reckon its a grand really well spent, its not that hard to do yourself either, lol I did the drivers side in no time once I made all the blues on the passenger side. Edited 27/12/08 07:03 AM by Spinifex Link to comment Share on other sites More sharing options...
