glimmerman Member 90 Member For: 15y 8m 12d Gender: Male Location: Penrith, NSW, OZtralia Posted 02/10/08 12:20 PM Share Posted 02/10/08 12:20 PM Gday guys,Just wondering, I want to do a brake system upgrade, and somewhere someone had territory rear brakes, on their Falcon... I don't know if they were on the Falcon as front brakes, or as rear again.Anyways, what I want to know, is if territory brakes are more powerful than Falcon brakes (may seem a stupid question, its a bigger car, and heavier - but then again, its the exact same engine as a Falcon)...And also, can they be used on a Falcon, now I have 18" wheels, so they should easily fit in if they are larger, and if they will offer more performance when braking, AND... can it be done easily, by someone who has a pretty good technical mind, but not exactly a machinist or mechanical engineer... Any hints and tips and stats on this sort of thing would be greatly appreciated... if you can tell me how to go about doing it, even better again... (Now it's not like I'm stupid, if its something I know I can tackle, I'll do it, otherwise I'll get it carried out by someone who can handle it, since its brakes... they are important lol).Cheers guysSteve Link to comment Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 16y 1m 22d Gender: Male Location: Blacktown! Posted 03/10/08 06:06 AM Share Posted 03/10/08 06:06 AM if you have standard BA brakes then you have 298mm rotors. The territory brakes are the same as the BF brakes and are 322mm. Technically they run the same caliper but have different brackets to hold the brake lines on. FTG on ebay and other forums sell a kit to upgrade to BF size which includes slotted rotor, pads and calipers. I dont think they would have rear territory brakes on the front, as there just single piston as opposed to twins on the front all a falcon. although they are a large size 328mmBrakes are an important thing, have a crack at changing them by all means, just be extra careful. I paid a local mechanic to do it, cost $120 better than me fart arsing round for a few hours. Link to comment Share on other sites More sharing options...
glimmerman Member 90 Member For: 15y 8m 12d Gender: Male Location: Penrith, NSW, OZtralia Posted 03/10/08 07:25 AM Author Share Posted 03/10/08 07:25 AM What did you get done by your local mechanic? like what was the change/upgrade? Link to comment Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 16y 1m 22d Gender: Male Location: Blacktown! Posted 03/10/08 07:34 AM Share Posted 03/10/08 07:34 AM check out my threadhttp://www.fordxr6turbo.com/forum/index.php?showtopic=49181the FG brakes are the same size and caliper as the BF falcon and territory. Only difference being the FG calipers mount on rear as opposed to the front side for falcon/territory Link to comment Share on other sites More sharing options...
chuck New Member 1 Member For: 1y 7m 3d Posted 22/09/22 10:45 AM Share Posted 22/09/22 10:45 AM Hi I've just started fitting all wheel drive turbo territory brakes to my ba xr6 turbo. ive installed the rears no probs just knotched the backing plates to clear the caliper brackets. front rotors fit nicely but the caliper bracket is about 6 to 8mm to thick in the mounting point to bolt them up. just wondering if theres an aftermarket mounting bracket or do I get the bracket machined down Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 22/09/22 11:13 AM Share Posted 22/09/22 11:13 AM I'd go to an engineering place and ask if machining the bracket is acceptable and just do that. Link to comment Share on other sites More sharing options...
F13N New Member 1 Member For: 1y 2m 15d Posted 10/02/23 11:57 AM Share Posted 10/02/23 11:57 AM On 22/9/2022 at 10:45 PM, chuck said: Hi I've just started fitting all wheel drive turbo territory brakes to my ba xr6 turbo. ive installed the rears no probs just knotched the backing plates to clear the caliper brackets. front rotors fit nicely but the caliper bracket is about 6 to 8mm to thick in the mounting point to bolt them up. just wondering if theres an aftermarket mounting bracket or do I get the bracket machined down Hi did you end up finishing this off if so what else did you have to do. I’ve just finished putting rears in. Did you use territory rotors or did you get bf/fg rotors? Link to comment Share on other sites More sharing options...
The Unforgiven Member 119 Member For: 17y 3m 2d Gender: Male Location: Adelaide Posted 12/02/23 11:44 AM Share Posted 12/02/23 11:44 AM I'd love to know of Turbo Territory front rotors will fit on an FG XR6T. I need to do pads on my FG and would prefer not to do Brembos as I'd also need new wheels. However, if I could fit the 340mm rotors onto the front with the larger caliper and 328mm rear rotors, it'd make for a very nice little upgrade coupled with some good pads. Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 3m 21d Location: Perth Posted 26/02/23 12:59 AM Share Posted 26/02/23 12:59 AM Matt from Race Brakes Sydney was selling a 355mm front rotor kit with PBR twin piston calipers so you can retain the stock 18/19" factory wheels. Quite a decent upgrade without the Brembo price tag. 1 Link to comment Share on other sites More sharing options...
stev57 New Member 1 Member For: 8m 13d Posted 12/08/23 04:44 AM Share Posted 12/08/23 04:44 AM Hi I have bf a falcon ute have 225/55/18 tyrer hit top of stub axle arm will territy stub axle bolt up. or thinking wheel spaces work Link to comment Share on other sites More sharing options...
