angus Member 38 Member For: 19y 10m 10d Gender: Male Location: Brisbane Posted 26/09/08 01:18 PM Share Posted 26/09/08 01:18 PM (edited) Hi all have had a few mods to my car done a while ago exhaust ,valve springs.edit etc and is has around 290rwkw but when I give it bit now and then it pings have been back to the tuner and made some reajustments and seemed to fix it but it is back again.The only thing I havent done to it yet is change the plugs which a lot of people seem to have done will this help with the problemany tips would be appreciatedoh and I do run it on bp ultimate all the time Edited 26/09/08 01:21 PM by angus Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/ Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 11m 1d Gender: Male Location: Broady, Melbourne Posted 26/09/08 02:17 PM Share Posted 26/09/08 02:17 PM What gear and what RPM do you get the ping? Your tuner should have already asked you that. Keep pulling a degree or two out until it stops. Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-740936 Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 18y 3m 16d Gender: Male Location: Brisbane, Queensland Posted 26/09/08 02:26 PM Share Posted 26/09/08 02:26 PM I dont think that changing your plugs will stop it pinging, do them anyway if they havent been changed for a while.when your tuner has been making adjustments, have they had the car on the dyno to see the results of the adjustments or to listen for when it pings to maybe get a better idea of what is causing it to ping?I would try getting fuel from a different servo, could also be a bad batch of fuel. Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-740940 Share on other sites More sharing options...
angus Member 38 Member For: 19y 10m 10d Gender: Male Location: Brisbane Posted 26/09/08 10:20 PM Author Share Posted 26/09/08 10:20 PM What gear and what RPM do you get the ping? Your tuner should have already asked you that. Keep pulling a degree or two out until it stops.I have 2nd cai with k&n filtervalve springs are donefull 3 and a half exhaust systemand edit with custom tuneas for when it happens it is around 4000-4500 rpm in 2nd gear. I dont know about 3 and 4th as the clutch isnt up to it at the moment but I new one is on the way.as for the tuner we took it for a test drive when I took it back so he could find out for himself and seemed to have fixed it but has reappeard Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-741018 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 5m 12d Gender: Male Location: SW Sydney Posted 26/09/08 10:24 PM Share Posted 26/09/08 10:24 PM So you've done injectors - what about a fuel pump? If you still have the stock pump it could be running out of fuel.... Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-741022 Share on other sites More sharing options...
angus Member 38 Member For: 19y 10m 10d Gender: Male Location: Brisbane Posted 26/09/08 11:28 PM Author Share Posted 26/09/08 11:28 PM Yes sorry forgot to add that have done the injectors too bosch 968shave been thinking it is the fuel pump too Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-741039 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 5m 12d Gender: Male Location: SW Sydney Posted 26/09/08 11:31 PM Share Posted 26/09/08 11:31 PM If you are still running the stock pump with 290rwkw - I'd say that's your problem. Generally most people upgrade the fuel pump around 270-280, its just to make sure you don't get this problem Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-741042 Share on other sites More sharing options...
angus Member 38 Member For: 19y 10m 10d Gender: Male Location: Brisbane Posted 26/09/08 11:39 PM Author Share Posted 26/09/08 11:39 PM Thanks for the advice senna was just looking at the process west ones they look like a quality itemdoes the car need to be retuned when doing a pump upgrade? Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-741047 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 5m 12d Gender: Male Location: SW Sydney Posted 26/09/08 11:41 PM Share Posted 26/09/08 11:41 PM Not necessarily, but considering your tuner has been playing around with your tune to get rid of the pinging - I'd say once the pump and surge tank goes in he will be able to raise the power up a little more. Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-741049 Share on other sites More sharing options...
TOM1111 Member 631 Member For: 17y 11m 21d Gender: Male Location: newcastle Posted 27/09/08 10:32 AM Share Posted 27/09/08 10:32 AM plenty of cars getting around with more then 300rwkw on a stock fuel pumpits just some are good and some are crap Link to comment https://www.fordxr6turbo.com/forum/topic/50131-pinging/#findComment-741258 Share on other sites More sharing options...
