SweetXR Member 124 Member For: 20y 9m Location: Melbourne, VIC Posted 25/07/03 12:22 PM Share Posted 25/07/03 12:22 PM Anyone got advice on necessity of installing a timer. Link to comment Share on other sites More sharing options...
Mondie Firm Member Donating Members 2,924 Member For: 21y 5m 22d Location: Adelaide Hills Posted 25/07/03 12:34 PM Share Posted 25/07/03 12:34 PM l dont think there is a need.Ford havent fitted one and feel confident enough in the car to give you a 3 year warranty. l wouldnt spend my money on one, it will be Fords problem if something goes wrong.There has been some threads on this before, try a search and you should find some additional info.Cheers Link to comment Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 21y 6m 13d Gender: Male Location: Outer east - Melbourne Posted 26/07/03 01:14 AM Share Posted 26/07/03 01:14 AM try here:Turbo Timer Thread Link to comment Share on other sites More sharing options...
Guest keithg Guests Posted 13/09/03 12:50 PM Share Posted 13/09/03 12:50 PM Since my turbo is screwed and being replaced as we speak, the dealer has recommended that I install a turbo timer in an attempt to reduce damage to my new one in the future.I am looking at the HKS timer type 1, can any one make recommendations or suggestions.Keith Link to comment Share on other sites More sharing options...
Guest EdMoorhouse Guests Posted 13/09/03 01:11 PM Share Posted 13/09/03 01:11 PM What stuffed the turbo? I was of the belief that they had a cooling system that eliminated the need for a timer. Link to comment Share on other sites More sharing options...
Guest keithg Guests Posted 13/09/03 01:16 PM Share Posted 13/09/03 01:16 PM The dealers comment was that it was getting pretty hot. The waste gate shaft that goes through the housing that connects to the actuator has given way and then seized in an open position. Also when the dealer went to take the Turbo off they broke a couple of the studs that hold the turbo on. They were purple right through. I am not sure why or how especially when it does have a cooling system, but I really don't want it to happen again, and I fugure for a couple of hundred bucks, it may save me some headahes in the future. Link to comment Share on other sites More sharing options...
Guest EdMoorhouse Guests Posted 13/09/03 01:42 PM Share Posted 13/09/03 01:42 PM There are 3 types of turbo timers. 1. A timer on the ignition that alows you to turn the car off and remove the key but the motor continues to run for a set time.2.The oil resivoir type. The oil flows slowly from the resevoir over the turbo bearings after you turn the motor off.3. Sit in the car and idle the engine a while and wait for the turbo to cool.(cheapest option) Link to comment Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 21y 1d Gender: Male Location: stanthorpe wine capital of qld. Posted 13/09/03 08:49 PM Share Posted 13/09/03 08:49 PM I do not believe a turbo timer will help this probelm as most of the heat in the housing is when you are pushing the car hard. the turbo timer just allows the oil to cycle around and over bearings to help it keep lubicated as the turbo winds down.Ian Link to comment Share on other sites More sharing options...
Guest Guests Posted 13/09/03 11:18 PM Share Posted 13/09/03 11:18 PM keigthg, WTF were you doing to the T? were you giving it a hard time or what. Please explain ? Link to comment Share on other sites More sharing options...
Guest keithg Guests Posted 14/09/03 04:39 AM Share Posted 14/09/03 04:39 AM keigthg, WTF were you doing to the T? were you giving it a hard time or what. Please explain ?Dude I have no idea?!!I have just over 26000 on mine and most of them are freeway klms. Go figure? Link to comment Share on other sites More sharing options...
