Guest newl Guests Posted 30/03/11 05:04 AM Share Posted 30/03/11 05:04 AM Return it to the place of purchase and save some cash for other mods. Turbo timers aren't needed. Link to comment Share on other sites More sharing options...
My_XR6_Turbo Member 282 Member For: 19y 8m 17d Posted 30/03/11 05:09 AM Share Posted 30/03/11 05:09 AM I spoke to Mr. Turbo in QLD and he highly recommended it. Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 16y 10m 24d Gender: Male Location: Melbourne Posted 30/03/11 05:14 AM Share Posted 30/03/11 05:14 AM Nah just wait 30 or so seconds after "spirited driving" before you turn it off, I.e don't do a massive skid then turn it off straight away. Most of us get into the habit of waitin a bit before turning it off if you know you just flogged the piss out of it. TT's are unnecessary. Link to comment Share on other sites More sharing options...
Pearse Member 21 Member For: 13y 1m 28d Gender: Male Location: Perth Posted 30/03/11 10:10 AM Share Posted 30/03/11 10:10 AM Yeah I'm sitting in it now for 30 seconds after a long drive, just as a practice, but I'd rather install the turbo timer, in regards to the alarm system it's turning off even when the keys in, and I hooked up the red - yellow, Blue - white possible with stripe, and green - red with green stripe, I havn't yet hooked up handbrake or o2 sensorI installed as per these instructions posted on a faggy skyline site after typing how to install apexi into google. (Hi.Since no one replied, so I decided to do this by hardwiring. Pretty easy stuff actually. Here's simple instruction:timer red goes to +12V constant (white + red stripe from ign)timer blue goes to ACC signal (blue from ign wiring)timer green goes to ON signal (black + yellow stripe from ign wiring)gray goes to e-brake signalwhite goes to o2 sensorblack to ECU ground if white connected to O2 sensor, to chassis if white not connected anywhere)I also figured out tonight that the light next to the 30 seconds countdown on the screen is orange, not green like it's supposed to be, like when I turn it to the voltage meter it's green, so I'm wondering if that leads to any sort of direct answer to which wires aren't connected/ are in the wrong place. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 3m 1d Gender: Male Location: Christchurch, New Zealand Posted 30/03/11 03:29 PM Share Posted 30/03/11 03:29 PM Are you 100% you have got the on part of the ignition wired correctly. Im like the others that have said its unnecessary, all you have to do is drive sedately for the last part of the trip home then you can just turn it off. Link to comment Share on other sites More sharing options...
Pearse Member 21 Member For: 13y 1m 28d Gender: Male Location: Perth Posted 31/03/11 09:25 AM Share Posted 31/03/11 09:25 AM (edited) I'm human therefore no, I'm not 100% sure, but I will try changing the acc and on wires to see if I did that backwards, and also hooking up the 02 sensor wire and the handbrake wire, if none of this works I'll be dissapointed, haha, the only reason I want it is for the convenience of not having to wait in your car for that long when you stop, and not having to drive sedately for a controlled time before stopping, also I'm a gadget man so it's cool to have, and it's most of the way in so I don't want to go back now, does the driving sedately thing apply to if I wanted to run 12-14psi of boost with the correct supporting mods in the near future? Edited 31/03/11 09:28 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
My_XR6_Turbo Member 282 Member For: 19y 8m 17d Posted 31/03/11 09:40 PM Share Posted 31/03/11 09:40 PM Where are you running the O2 sensor wire to? Link to comment Share on other sites More sharing options...
Pearse Member 21 Member For: 13y 1m 28d Gender: Male Location: Perth Posted 01/04/11 09:29 AM Share Posted 01/04/11 09:29 AM I haven't figured that out yet, but today I accidentally touched one or all of the 3 wires together whilst my car was running and it died, now I can't get it to start again, any help would be appreciated Link to comment Share on other sites More sharing options...
FPV6T UNDERCOAT CRUISER!!! Donating Members 1,655 Member For: 15y 3m 1d Gender: Male Location: brisbane Posted 01/04/11 09:38 AM Share Posted 01/04/11 09:38 AM Blown the main engine fuse?? Link to comment Share on other sites More sharing options...
Pearse Member 21 Member For: 13y 1m 28d Gender: Male Location: Perth Posted 01/04/11 09:58 AM Share Posted 01/04/11 09:58 AM Blown the main engine fuse??I just checked all of the fuses in the car and in the engine bay, they all seem fine, plus I'm getting power to the cluster in the from of my odometer reading is there but when I attach my test light to the main power coming off the ignition barrel/ constant 12v is doesn't light up anymore Link to comment Share on other sites More sharing options...
