xrturbomatty Member 79 Member For: 16y 1d Posted 30/05/08 03:36 AM Share Posted 30/05/08 03:36 AM Hey my car is running pretty rough the neddle jumps when idling anyone seen this before Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 9m 6d Gender: Male Posted 30/05/08 05:12 AM Share Posted 30/05/08 05:12 AM all my idle problems were fixed with a good clean of the throttle body.give it a shot mate! nulon do a throttle body and carby cleaner, use it liberally, and get the cloth right in there. worked for me! Link to comment Share on other sites More sharing options...
xrturbomatty Member 79 Member For: 16y 1d Posted 30/05/08 05:28 AM Author Share Posted 30/05/08 05:28 AM all my idle problems were fixed with a good clean of the throttle body.give it a shot mate! nulon do a throttle body and carby cleaner, use it liberally, and get the cloth right in there. worked for me!Hey mate already tried that a few timesi have new plugs im running 264rwkw could it be valve springs or coil packs thanks Link to comment Share on other sites More sharing options...
jbute Member 95 Member For: 17y 1m 9d Location: NSW Posted 30/05/08 06:19 AM Share Posted 30/05/08 06:19 AM Had the same problem, coil 5 was stuffed on mine changed it fine. I would be it would be one of your coils, you just needs to find out which one.If it was value spring it would go away after a few minutes when they cool down usually. I had taken mine to ford 6 times kept telling me fixed drive away same problem, went around my mates house he is a Expensive Daewoo tech (But drives a 450+ XR6T !) pulled up in his drive way had one listen went around the block he said coil. Told ford this, they said yeah didn't well tell you that we ordered one (Yeah right) changed been fine since. Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 1m 14d Gender: Male Location: SYDNEY Posted 30/05/08 06:29 AM Share Posted 30/05/08 06:29 AM (edited) Mate I got the same problem and still cant find it, I have done:TB cleanCoils packs gangeSpark plugs changeInsulated the coil packs and wiresTPS changeO2 sensor changeand still havent found the problem, I was told it is the PPS (Pedal Positioning Sensor) So that's next on the list..Pete Edited 30/05/08 06:33 AM by LUMO Link to comment Share on other sites More sharing options...
xrturbomatty Member 79 Member For: 16y 1d Posted 30/05/08 06:47 AM Author Share Posted 30/05/08 06:47 AM thanks for your help guys how can u tell which coils are screwed Link to comment Share on other sites More sharing options...
Outlaw357 Member 12 Member For: 15y 9m 23d Gender: Male Location: Gunnedah NSW Posted 05/06/08 07:17 AM Share Posted 05/06/08 07:17 AM Hi guys! noticed a few people with the dreaded rough idle.Also interesting to note a few are running K&N oiled air filters.I have heard of others spending a fortune trying to fix rough idle & this cost youNothing but time.Also may fix that rough change in some autos?Have a go it may also work for you- Have a read below. :banghead2: The Idle Speed Controller Valve, or otherwise known as the Idle Air Bypass System, is responsible for maintaining a smooth, and consistent idle, under different Engine Loads, and temperatures.It does this by allowing a certain amount of air, to bypass the Throttle Body Butterfly, thereby increasing the amount of air entering the engine, under certain conditions, thereby increasing Engine RPM.The Idle speed control valve is controlled by the EEC-V Engine Management system, and is a spring loaded stepped motor, that opens a small valve, that allows air to flow. It is actually quite common for this valve to get gummed up and slighty jammed, by carbon deposits, oil, and other foreign materials.This is especially the case if an aftermarket air cleaner, that is oil based (Such as K & N air Filters), as the Oil is slowly sucked in to the Idle speed controller, and slowly blocks off, and jams the air passage and Valve.Symptoms of a jammed, or dirty Idle Speed Controller include, · 1) Poor idle quality in cold temperatures. · 2) Engine stalling under load (Eg Power steering operation, Air Conditioning, etc), under closed throttle (Idle) conditions. · 3) Rough Gear changes on Automatics when changing from second, to first gear, (Engine speed surging). · 4) Engine RPM surging at idle, for no reason. (I.E. Engine increasing RPM to greater than 1000rpm, for no apparent reason).Cleaning the Idle Speed ControllerThe Idle speed controller can be easily cleaned, and is recommended if the above symptoms exist. 1 Link to comment Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 18y 6m 25d Gender: Male Location: NSW Posted 05/06/08 07:21 AM Share Posted 05/06/08 07:21 AM Sounds like some useful info there Link to comment Share on other sites More sharing options...
XRPete Member 673 Member For: 16y 6m 18d Gender: Male Location: Here Posted 05/06/08 09:57 AM Share Posted 05/06/08 09:57 AM Where is the valve and how hard is it to clean? Link to comment Share on other sites More sharing options...
Outlaw357 Member 12 Member For: 15y 9m 23d Gender: Male Location: Gunnedah NSW Posted 06/06/08 02:22 AM Share Posted 06/06/08 02:22 AM Where is the valve and how hard is it to clean? This is info on how to clean!If attachment wont open PM me & will send to you.Cheers, David.Cleaning_the_Idle_Speed_Controller.doc Link to comment Share on other sites More sharing options...
