Troy.lone Member 2 Member For: 16y 30d Gender: Male Location: Queensland Posted 27/04/08 08:49 AM Share Posted 27/04/08 08:49 AM I recently brought 04 BA XR6 T 5-speed manual, which had 100K on board. On test drive car did alright, though it is my first turbo car, except the clutch felt hard.Since then I have done 100K service, changed every filter and oil in it. Clutch became normal and everything was going great.It has started a snag, the RPM on idling goes anywhere from 200 - 1500 and I can hear some engine noise like rattling of metal, and lately engine stops as trying to slow down. I got dyno-test done on it, results showed perfect air to fuel ration and no technical issues and was producing 279 HP at the wheels. I also took it to the other mechanic and said about the idling, they tested and said it is fine. I use BP Ultimate fuel all the time (98 Octane)Can anyone please suggest anything, is it normal for a turbo car or my car has got some serious issues. I love XR6 Turbo and want to keep it.Any help will be appreciated. Link to comment Share on other sites More sharing options...
djp123 Member 3 Member For: 15y 11m 24d Posted 27/04/08 09:45 AM Share Posted 27/04/08 09:45 AM Sounds to me like you have some sort of issue with the throttle body (poss. dirty) & the noise you are hearing is the drive belt tensioner whipping back & forth when the idle drops. Does the engine check light come on at all? Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 16y 10m 5d Gender: Male Location: Nrth Qld Posted 27/04/08 10:14 AM Share Posted 27/04/08 10:14 AM Give the TB a good clean. Link to comment Share on other sites More sharing options...
Chich Damn You's A Sexy Chich Member 3,843 Member For: 16y 2m 3d Gender: Male Location: Your House Posted 27/04/08 10:34 AM Share Posted 27/04/08 10:34 AM I'd say throttle body as well, had the same problem a while ago with my n/a falcon, and after a lot of searching for the problem that was all it was... Link to comment Share on other sites More sharing options...
neo Member 376 Member For: 16y 1m 9d Gender: Male Location: The Ville Posted 27/04/08 10:54 AM Share Posted 27/04/08 10:54 AM strange Questing but whats the best way to clean it and whats the best to clean it with? Link to comment Share on other sites More sharing options...
Chich Damn You's A Sexy Chich Member 3,843 Member For: 16y 2m 3d Gender: Male Location: Your House Posted 27/04/08 10:59 AM Share Posted 27/04/08 10:59 AM I just used some nulon carby and throttle body cleaner as per instructions don't over do it but. Link to comment Share on other sites More sharing options...
Troy.lone Member 2 Member For: 16y 30d Gender: Male Location: Queensland Posted 28/04/08 11:43 AM Author Share Posted 28/04/08 11:43 AM Sounds to me like you have some sort of issue with the throttle body (poss. dirty) & the noise you are hearing is the drive belt tensioner whipping back & forth when the idle drops. Does the engine check light come on at all?I changed the idler bearing and got the timing done, even treated it with the Fuel injection sytem...but doens't seem to work Link to comment Share on other sites More sharing options...
jbute Member 95 Member For: 17y 2m Location: NSW Posted 28/04/08 01:00 PM Share Posted 28/04/08 01:00 PM Coils & spark plugs Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 16y 10m 25d Gender: Male Location: Melbourne Posted 29/04/08 11:43 PM Share Posted 29/04/08 11:43 PM Mine does the same thing, slowing down to the lights occasionally it dips down to like 200rpm then back up to normal. Link to comment Share on other sites More sharing options...
skunk Member 236 Member For: 16y 5m 25d Gender: Male Location: melb Posted 30/04/08 02:07 AM Share Posted 30/04/08 02:07 AM mine does the same too.. I tihnk its jsut a manual thing.. Link to comment Share on other sites More sharing options...
