Guest gctaylor Guests Posted 26/12/03 01:56 AM Share Posted 26/12/03 01:56 AM :festive: My manual is averaging 14.2 litres/100km. Mostly city and suburban driving (27000km to date).On country trips the consumption improves to the 8's and 9'sSafe driving/riding to all Link to comment Share on other sites More sharing options...
sport Member 62 Member For: 20y 11m 28d Posted 26/12/03 10:58 AM Share Posted 26/12/03 10:58 AM I drove mine auto ute in "granny Mode" for one tank and the best I could get was 14.9 so I just drive normally (giving it a reasonable squirt most of the time) and get about 16.5 which I reckon is OK. I am happy to blow 2 extra l/100k and enjoy having the turbo grunt. I am not ready for "granny mode" yet. Link to comment Share on other sites More sharing options...
teebone Member 183 Member For: 20y 5m 15d Location: South of Melbourne, near the sea Posted 27/12/03 08:01 AM Share Posted 27/12/03 08:01 AM Thanks for the info guys - what I was really looking for some answers on from any of the techheads out there, was why the auto T gives better economy results under controlled testing than the manual, whereas with the V8's the expected outcome is achieved (ie manual better than auto). Link to comment Share on other sites More sharing options...
ducatijb Lifetime Members 3,448 Member For: 21y 14d Gender: Male Location: sydney Posted 27/12/03 07:22 PM Share Posted 27/12/03 07:22 PM On the Geelong Tour I was sitting on 115kph in a line of 6 cars Mine is auto sitting on 2200 rpm and the manual behind me was sitting on 2400rpm(cramorr) Maybe the answer is here More revs= more fuel Link to comment Share on other sites More sharing options...
trbo 6 Member 230 Member For: 20y 1m 15d Gender: Male Posted 10/03/04 11:57 PM Share Posted 10/03/04 11:57 PM Is anyone with the APS II kit installed recieving wrong reading from their fuel consumption.Before the installation I was getting an average of about 15L/100k's, which equates to 466L to about 70 Litres of fuel.Now the reading is more like 12L/100k's which in theory should be 588L from 70 Litres, and I'm definately not getting that much.Peter maybe you can answer this one. And maybe offer a quick fix?Cheers 1 Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 20y 11m 22d Gender: Male Location: Victoria Posted 11/03/04 12:02 AM Share Posted 11/03/04 12:02 AM Here's a link that may help answer some of your questions:L/100km Before And After The "chip" what's happening with the chipped cars ? Link to comment Share on other sites More sharing options...
trbo 6 Member 230 Member For: 20y 1m 15d Gender: Male Posted 11/03/04 12:13 AM Share Posted 11/03/04 12:13 AM Here's a link that may help answer some of your questions:L/100km Before And After The "chip" what's happening with the chipped cars ? Thanks answered all questions and then some. Link to comment Share on other sites More sharing options...
aps Member 1,505 Member For: 21y 1m 10d Posted 11/03/04 09:40 PM Share Posted 11/03/04 09:40 PM Is anyone with the APS II kit installed recieving wrong reading from their fuel consumption.Before the installation I was getting an average of about 15L/100k's, which equates to 466L to about 70 Litres of fuel.Now the reading is more like 12L/100k's which in theory should be 588L from 70 Litres, and I'm definately not getting that much.Peter maybe you can answer this one. And maybe offer a quick fix?CheersTrbo6, the trip computer makes its calculations from the duty cycle of the fuel injectors. When larger injectors are installed the fuel flow increases for the same amount of injector duty cycle. This is the reason as to why the trip computer makes the incorrect calculation for fuel economy. We currently do not have a method to rectify this issue. This problem applies to any xr6t fitted with larger than stock fuel injectors. :( The injector duty cycle is the rate at which the injector opens and closes, the higher the duty cycle the longer duration that the injector stays open. :APS Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 20y 7m 30d Gender: Male Location: NSW Posted 11/03/04 10:42 PM Share Posted 11/03/04 10:42 PM HI Peter,This error in readings should remain fairly constant? I assume that it will be the percentage of increase in injector size or am I totally off in which case ill duck for cover, by the way im enjoying the new found power the car hasnt missed a beatCheers Frank Link to comment Share on other sites More sharing options...
Guest DEVO Guests Posted 13/03/04 06:57 AM Share Posted 13/03/04 06:57 AM Just recently put in a K&N panel filter and have noticed fuel consumption has gone up dramatically- contrary to everyone's opinion of what happens when you put a K&N in. I was usually getting about 15l/100km, even with the lead foot. Now, after about 600klm with it in, I seem to be getting about 16.7l/100klm (of course maintaining the lead foot). This seems pretty high to me, I mean I have not changed anything else, still run Optimax every tank, still like to get to 60klm/h as promptly as possible.Does anyone have any suggestions? apart from the obvious changing back. I have heard you can get the chip "flashed" to erase the fuel/ignition curves so it learns faster- anyone know?Thanks. Link to comment Share on other sites More sharing options...
