sixfan Flaccid Member Donating Members 2,503 Member For: 20y 10m 30d Gender: Male Location: NOONAMAH, go figure..... Posted 17/02/08 09:01 AM Share Posted 17/02/08 09:01 AM I suggest the following format(Shamelessly copied from elsewhere....)Your Name: Car Make and Model:Circuit Name: Lap time: ModificationsEngine: Power: Suspension: Tyres: Brakes: Body weight: Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 18y 9m 13d Gender: Male Location: The 8th Dimension Posted 17/02/08 09:29 AM Share Posted 17/02/08 09:29 AM If your times are posted here, post a message below detailing what modifications your car has. RWKW figures, dyno sheets, timeslips are mandatory. Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 15y 8m 29d Gender: Male Location: Melbourne Posted 11/05/09 11:31 AM Share Posted 11/05/09 11:31 AM Your Name: Joel JenkinsCar Make and Model: Ford XR6 Turbo BA MKIICircuit Name: SandownEvent: FFCC Sandown Sprint Date: 10/5/2009 Lap time: 1'33.98Modifications: NoneEngine: StandardPower: 198.9 RWKWSuspension: StandardTyres: Seriously used Yokohama A048 ($80 a tyre)Brakes: Standard Ford pads, Standard Ford rotors, 298mm front, 302mm? rearBody weight: Standard 1700 kgs?You can view the time on http://www.natsoft.com.au/results/ Link to comment Share on other sites More sharing options...
jsmith Donating Members 712 Member For: 16y 5m 26d Gender: Male Location: Blacktown Posted 11/05/09 03:38 PM Share Posted 11/05/09 03:38 PM Your Name: Jeremy SmithCar Make and Model: Fiat 124BC sports coupe (U2L sports sedan)Circuit Name: Wakefield ParkLap time: 1:06.57Modifications Engine: Fiat 16 valve, 2 litre, naturally aspirated.Power: 275BHPSuspension: totally custom, full rose-jointed, fabricated control arms f+r, adjustable coil overs etc etc. was a spool diff, now a ZF ramp load clutch pack diff.Tyres: were 15x8 slicks, now 16x10 slicks.Brakes: 4 spot calipers running on approx 290mm vented discs all round, dual master cylinders with brake bias adjustment barBody weight: Approx 850kg with full tank fuel and driver.natsoft timing- http://www.natsoft.com.au/cgi-bin/results..../2009.WAKE.S5.Y. Link to comment Share on other sites More sharing options...
INASNT Member 361 Member For: 17y 7m 30d Gender: Male Location: Melbourne Posted 20/06/09 07:38 AM Share Posted 20/06/09 07:38 AM Your Name: Joel JenkinsCar Make and Model: Ford XR6 Turbo BA MKIICircuit Name: SandownEvent: FFCC Sandown Sprint Date: 10/5/2009 Lap time: 1'33.98Modifications: NoneEngine: StandardPower: 198.9 RWKWSuspension: StandardTyres: Seriously used Yokohama A048 ($80 a tyre)Brakes: Standard Ford pads, Standard Ford rotors, 298mm front, 302mm? rearBody weight: Standard 1700 kgs?You can view the time on http://www.natsoft.com.au/results/No other sandown times from anyone?Was at a driver dynamics day watching some friends a few weeks ago at sandown and they were doing a 1.35 in a integra type r. Was going to enter my G6ET but I have no faith in the brakes lasting more than a few laps. Done Sandown a few times in my 320rwkw skyline a few yearsa go Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 15y 8m 29d Gender: Male Location: Melbourne Posted 23/06/09 01:22 PM Share Posted 23/06/09 01:22 PM No other sandown times from anyone?Was at a driver dynamics day watching some friends a few weeks ago at sandown and they were doing a 1.35 in a integra type r. Was going to enter my G6ET but I have no faith in the brakes lasting more than a few laps. Done Sandown a few times in my 320rwkw skyline a few yearsa goSandown is a real power and brakes circuit, not really suited to the Integra.While it would be quick around the corners it doesn't have the grunt to accelerate out of the tight corners and down the long straights.I was at the PIARC Sprints at Phillip Island and I think that PI would suit the integra much better as its a lot of long sweeping turns where it could maintain a high corner speed.Because the XR6T is so heavy it really works the front right and understeers a lot on the sweepers. Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 15y 8m 29d Gender: Male Location: Melbourne Posted 23/06/09 01:26 PM Share Posted 23/06/09 01:26 PM Your Name: Joel JenkinsCar Make and Model: Ford XR6 Turbo BA MKIICircuit Name: Phillip IslandEvent: PIARC SprintDate: 31/5/2009 Lap time: 2'03.791Modifications: NoneEngine: StandardPower: 198.9 RWKWSuspension: StandardTyres: Seriously used Yokohama A048 ($80 a tyre)Brakes: Standard Ford pads, Standard Ford rotors, 298mm front, 302mm rearBody weight: 1780You can view the time on http://www.natsoft.com.au/results Link to comment Share on other sites More sharing options...
INASNT Member 361 Member For: 17y 7m 30d Gender: Male Location: Melbourne Posted 24/06/09 12:16 AM Share Posted 24/06/09 12:16 AM Sandown is a real power and brakes circuit, not really suited to the Integra.While it would be quick around the corners it doesn't have the grunt to accelerate out of the tight corners and down the long straights.I was at the PIARC Sprints at Phillip Island and I think that PI would suit the integra much better as its a lot of long sweeping turns where it could maintain a high corner speed.Because the XR6T is so heavy it really works the front right and understeers a lot on the sweepers.The integra had a lot of work done to it including fairly worked engine (around 180kw@flywheel), adustable tein suspension, semi comps but stock brakes.There was a FG XR6 there also, had a quick talk to the owner and he said the car was struggling in the high rpm range and could only do 160 clicks down the main straight.There were 2 R35 GTR's racing also who were realing off easy 1:24's with fairly armature drivers. Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 15y 8m 29d Gender: Male Location: Melbourne Posted 29/06/09 12:31 PM Share Posted 29/06/09 12:31 PM Any other times? Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 15y 9m 26d Gender: Male Location: Sydney Posted 30/06/09 07:23 AM Share Posted 30/06/09 07:23 AM Your Name: Paul NobleCar Make and Model: FGXR6TCircuit Name: MarulanLap time: 47.47 (handtimed)Modifications: None at the timeEngine: Stock as a rockPower: 270kW at flywheel est.Suspension: StockTyres: Kumho KU36 front, Falken Azenis RT215 rearBrakes: Stock with EBC red padsBody weight:77kg (79.25kg after a 6pack of beer) 1 Link to comment Share on other sites More sharing options...
