Circuit Racing
sixfan
  • Flaccid Member
  • Member For: 20y 10m 29d
I suggest the following format
(Shamelessly copied from elsewhere....)
Your Name:
Car Make and Model:
Circuit Name:
Lap time:
Modifications
Engine:
Power:
Suspension:
Tyres:
Brakes:
Body weight:
  • Still have a turbo, it's just on a diesel.
  • Member For: 18y 9m 12d
If your times are posted here, post a message below detailing what modifications your car has. RWKW figures, dyno sheets, timeslips are mandatory.
  • 1 year later...
  • Member For: 15y 8m 29d
Your Name: Joel Jenkins
Car Make and Model: Ford XR6 Turbo BA MKII
Circuit Name: Sandown
Event: FFCC Sandown Sprint
Date: 10/5/2009
Lap time: 1'33.98
Modifications: None
Engine: Standard
Power: 198.9 RWKW
Suspension: Standard
Tyres: Seriously used Yokohama A048 ($80 a tyre)
Brakes: Standard Ford pads, Standard Ford rotors, 298mm front, 302mm? rear
Body weight: Standard 1700 kgs?
You can view the time on
http://www.natsoft.com.au/results/
  • Member For: 16y 5m 26d
Your Name: Jeremy Smith
Car Make and Model: Fiat 124BC sports coupe (U2L sports sedan)
Circuit Name: Wakefield Park
Lap time: 1:06.57
Modifications
Engine: Fiat 16 valve, 2 litre, naturally aspirated.
Power: 275BHP
Suspension: totally custom, full rose-jointed, fabricated control arms f+r, adjustable coil overs etc etc. was a spool diff, now a ZF ramp load clutch pack diff.
Tyres: were 15x8 slicks, now 16x10 slicks.
Brakes: 4 spot calipers running on approx 290mm vented discs all round, dual master cylinders with brake bias adjustment bar
Body weight: Approx 850kg with full tank fuel and driver.
natsoft timing- http://www.natsoft.com.au/cgi-bin/results..../2009.WAKE.S5.Y.
  • 1 month later...
  • Member For: 17y 7m 29d
Date: 10/5/2009
Lap time: 1'33.98
Modifications: None
Engine: Standard
Power: 198.9 RWKW
No other sandown times from anyone?
Was at a driver dynamics day watching some friends a few weeks ago at sandown and they were doing a 1.35 in a integra type r.
Was going to enter my G6ET but I have no faith in the brakes lasting more than a few laps. Done Sandown a few times in my 320rwkw skyline a few yearsa go
Sandown is a real power and brakes circuit, not really suited to the Integra.
While it would be quick around the corners it doesn't have the grunt to accelerate out of the tight corners and down the long straights.
I was at the PIARC Sprints at Phillip Island and I think that PI would suit the integra much better as its a lot of long sweeping turns where it could maintain a high corner speed.
Because the XR6T is so heavy it really works the front right and understeers a lot on the sweepers.
Circuit Name: Phillip Island
Event: PIARC Sprint
Date: 31/5/2009
Lap time: 2'03.791
Modifications: None
Engine: Standard
Power: 198.9 RWKW
Brakes: Standard Ford pads, Standard Ford rotors, 298mm front, 302mm rear
Body weight: 1780
The integra had a lot of work done to it including fairly worked engine (around 180kw@flywheel), adustable tein suspension, semi comps but stock brakes.
There was a FG XR6 there also, had a quick talk to the owner and he said the car was struggling in the high rpm range and could only do 160 clicks down the main straight.
There were 2 R35 GTR's racing also who were realing off easy 1:24's with fairly armature drivers.
  • Member For: 15y 9m 25d
Your Name: Paul Noble
Car Make and Model: FGXR6T
Circuit Name: Marulan
Lap time: 47.47 (handtimed)
Modifications: None at the time
Engine: Stock as a rock
Power: 270kW at flywheel est.
Suspension: Stock
Tyres: Kumho KU36 front, Falken Azenis RT215 rear
Brakes: Stock with EBC red pads
Body weight:77kg (79.25kg after a 6pack of beer)
