Mods To Power Comparison
xr_velocity
  • BACK SLOWER THEN EVER!
  • Member For: 16y 8m 25d
Car: BA MkII XR6 Turbo
Trans: 4 speed auto
Power: 276rwkw
Boost: 12-14psi
Induction: Monza Mspec Intercooler + Plazmaman UBP
Turbo: stock
Valve Springs: Nizpro
Exhaust: stock
Fuel system: Nizpro redrilled Squirter
Power adder: Custom tuner by BTA
  • Member For: 17y 1m 6d
Name: Ross aka Velluto
Trans: T56, Atomic clutch - 10 puck sintered ceramic/bronze
Power: 333rwkw
Boost: 13psi
Induction: Nizpro Stage 2 kit
Turbo: 10lb actuator, 36mm swing valve, ported
Exhaust: X-Force 4" d/d, 3.5" cat into 2x2.5" pipes
Fuel system: Nizpro injectors- supplied with Stage 2 kit, Walbro in-tank fuel pump
Power adder: Custom tuned by Robin @ Torque Perf in Auckland, NZ
  • Member For: 18y 1m 21d
Car: BA MkI
Trans: broke the T5 so got a T56, with Extreme Clutch 10 puck + F/Wheel
Power: 331rwkw
Boost: 15psi
Induction: stock, typhoon CIA
Turbo: stock ,12.5psi actuator
Valve Springs: Crow Springs & retainers
Exhaust: X-Force 3.5" dump, 5" cat into twin 2.5
Fuel system: redrilled taxi injectors found em in the shed.... Walbro fuel pump
Power adder:Edit & Custom tuned by Con @ C&V
pete
  • 2 months later...
  • THE PSYCHO XRT
  • Member For: 18y 3m 20d
  • Gender: Not Telling
Car: BA MkI 2004 XR6T (Citric Acid)
Trans: 4 Speed Auto, PWR H/D Transmission Cooler and Shifts firmed by Nizpro
Power: 306rwkw
Boost: 14psi
Induction: Monza FMIC with XR8 CAI with 3rd Custom CAI
Turbo: Stock ,9psi Actuator
Valve Springs: Nizpro Cobra Valve Springs
Exhaust: Full S/S X-Force 3.5" dump, 3.5" Metal cat into twin 2.5 with quad tips from Nizpro
Fuel system: Siemens 60lb Injectors
Power adder: Edit & Custom tuned by the team @ Nizpro
San
  • Member For: 17y 22d
Car: BFII XR6T December 2006
Trans: T56, Mal Wood Option 3
Power: 326 rwkw
Boost: 15psi
Induction: Prototype Wog Cooler, typhoon Snorkel, KNN Panel, Type 3 TCC BOV, stock plenum
Turbo: Stock
Valve Springs: stock
Exhaust: Full stainless steel 3" X-force zorst system
Fuel system: Nizpro 72lb Injectors, Walbro 550hp pump
Power adder: Edit By BPT Motorsport
12.9 @ 112 mph
Edited by DRTYBOOST
  • 2 months later...
  • Member For: 16y 10m 2d
WTF??? Every tuner I speak to tells me I CANNOT get 300rwkw without valve springs, everyone here is running 300 without them. HPF told me without valve springs I would only be getting 240rwkw!!!!
RAPID CAI, IC, Siemens injectors, Flash box, High flow cat
