Mods To Power Comparison
xr_velocity
  • Member For: 9y 6m 27d
15 hours ago, k31th said:
did you just collate that from the thread content?
:spoton: nice work
Yep.
Interesting how the Monza's evaporate from that list as power gets over 320kw/14-15psi.
I got 321.3rwkw but hoping to get 350-360 with a Plazmaman 700hp cooler and re-tune.
5 hours ago, MattyP said:
Monzas aren't great, you're turbo is a tad strange and your exhaust and injectors are really limiting you
How so re injectors? Thought the 60lb's were good for 400rwkw?
I have been told they're not ideal anyway in the FG length and may switch to ID1000/Bosch.
Also interested to know why you find the turbo strange.
  • MattyP
  • Cruise Control
  • Member For: 11y 11m 14d
It's not very common that's all, it's just a 3540 with a billet wheel and wastegate work done. It's good just not seen very often
60lbs have been redundant for a while now and.you'd really be pushing them to get 400 out of em. I highly doubt you could get that high safely
Kpm/id are great injectors
Great flow and spray pattern plus ethanol ready
  • ...JD TUNING ADELAIDE...
  • Member For: 15y 10m 18d
Sounds like he's a customer of a workshop down south so 60lb dekas are still common injectors at this shop
  • Like 2
  • Member For: 11y 1m 23d
Car: 2010 FG XR6 Turbo Upgrade
Power: 321rwkw
Boost: 15psi
Induction: V8 lower, K&N panel
Intercooler: Monza
Turbo: Hypergear ATR45SS 0.5A/R
Valve Springs: Plazmaman Spec 1
Exhaust: Stock 3" with Venom 5" 100cpi cat, centre muffler removed
Fuel: Siemens 60lb
Tuning: HPT
How's that hypergear turbo go? My friends got em in their r34s and swear by em. Did you send off your stock one to the guy and he high flowed it? That's what they did to theirs and gained heaps of power earlier and all over the rev range
Its a journal bearing. Locally assembled and balanced from Chinese parts I think.
 Will see full boost around 2800rpm if your loading up in a higher gear.
Nice 40mm internal gate with choice of actuator Springs, I have 15psi actuator.
Apparently this spec can flow 420rwkw on P98 and has seen 490rwkw on E85 with the 0.70A/R comp cover option.
So far I've only seen 320kw from it (@ gate pressure, 15psi), likely due to cooler and exhaust restrictions.
I am reserving judgement until next Monday when the Plaz cooler is installed and ECU is re-tuned.
Will post up results.
P.S Tao, the manager of Hypergear, is very highly respected in Skyline circles and is one of the most helpful and friendly guys I've spoken to in the automotive industry. Operates from Melbourne, been around since around early 2000s
Got it as complete unit, but they do high flow rebuilds also
  • Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds
  • Cruise Control
  • Member For: 13y 5m 28d
Car: 2008 FG F6 Ute
Trans: 6 speed auto
Turbo: stock
Boost: 15 PSI I think
Valve springs: Stock
Cooler: Plazmaman stage 2 (800hp kit)
Fueling: stock
Exhaust: Venom hi-flow cat, stock at back
Power: 333RWKW
Tuner: HP tuners
Mods since dyno - ID1000 injectors
Mods planned - 460l/h intank fuel pump, E85 tune, Crow valve springs
  • Member For: 15y 4m 26d
Car: 2010 FG XR50t
Trans: 6 speed auto
Turbo: stock
Boost: 13 PSI Tapering to 12 PSI
Cooler: Stock
Fueling: KPM1000cc Inj
Exhaust: Stock exhaust "HI-Flow" cat,
Power: 288 RWKW
Tuner: Myself with HP Tuners
Now on e85 with supporting mods 17psi stock gt3576, Power ???
  • RNS10S
  • Member For: 17y 8m 2d
Car: 2008 BF XR6T Sedan
Power: 476rwkw
Boost: 24psi
Induction: PW Racel
Intercooler: PW Stg 2
Turbo:  PTE 6235
Valve Springs: PAC springs
Exhaust: FG 4" xforce modded to fit BF
Fule: Caltex e-flex (E70)
Fuel setup: Walbro 255 intank, Plaz surge, Aeromotive A1000 with speed controller, Bosch 1000cc injectors
Tuning: Autotech Engineering
