Mods To Power Comparison
xr_velocity
  • Member For: 11y 3m 2d
Bf2 xr6 t
Zf trans
Power: 290 rwkw
Boost: 10 psi
Exhaust: 4" venom cat
Cooler: F6
Fuel: Deka 60's, walbro intank
Induction: enclosed pod filter with CAI
Turbo: stock
Tuning: HP tuning
  • Silver Donating Members
  • Member For: 16y 5m 10d
06/2006 BF2
Zf trans
Power: 335 rwkw, 1200nm.
Boost: 15psi
Zorst: Standard with cat and center muffler delete
Intercooler: Stage 3.5 rapid cooler and piping.
Fuel system: 60lb injectors & walbro intank
Induction:custom 4" intake and airbox, K&N 4"x9" cone filter, plazmaman plenum.
Turbo: Stock with 12lb actuator and flapper mod
Tuning: Xcal 3 box, Tuned by Torque Performance, Auckland.
  • Member For: 11y 1m 18d
Name Matt
Car: BA Mk2 XR6 Turbo
Trans: 6spd man
Power: 336rwkw
Boost: 14
Induction: growler, monza cooler (this sh*tty aftermarket cooler is the bottleneck for power at the moment, don't waste money on these ones it dropped my intake temp by about 2deg)
Turbo: Stock with ported gate and custom flapper, 12lb actuator
Valve Springs: atomic
Exhaust: xforce 4" dump, 5" cat, 3.5" single
Fuel system: ID1000 injectors, upgraded pump
Power adder: SCT Flash tuner, tuned by Xtreme Ford
  • Menace
  • Member For: 12y 11m 29d
Ya got all the good stuff bar your intercooler and piping setup + maybe a surgey is on the cards... hit up the ethanol with a good tuner and give'er another push ;) it'll be worth it
Yeah I would love to open 'er up and get some decent guts in it, but it's down for the count at the moment (see topic I started yesterday...). I also forgot to mention that I'm still running the factory clutch aha, which is slipping pretty bad. So once I get the lecy problem sorted a malwood opt3 will be getting dropped in. After that I'll sort out the piping and cooler :D
  • in the mid....not the bum like some
  • Member For: 10y 11m 27d
Car: BA 2003 XR6 Turbo stock motor 170k
Trans: Stock BTR atm
Power: 408rwkw/389rwkw
Boost: 18psi flat/16psi rising to 17.5psi
Intercooler: RAPID 500x400x90 standard hot-side & 3" cold-side
Induction: 4" turbo-side enclosed & FG inlet manifold/fuel rail
Turbo: GTX3582R with 7psi actuator & standard flapper
Valve Springs: CROW
Exhaust: 3.5" dump with separate w/gate pipe & de-cat with 3" stainless exhaust
Fuel system: Walbro in-tank feeding 044 Process West surge tank & 60lb Dekkas
Power adder: SCT tuning by Heinrich Performance using E55 fuel
Edited by Skids4kids
  • 2 weeks later...
  • Member For: 10y 8m 29d
Car: bf xr6t
Trans: 6spd manual , malwood cluctch
Power:316kw
Boost:13-18psi
Induction:k&n air filter , unsure of cooler but not stock
Turbo:stock
Valve springs: stock
Exhaust: xforce stainless (4" dump, high flow cat, dual 2.5" )
Fuel system: 60lb injectors , aero motive 340 fuel pump
Power adder: capa ford flash 2
Edited by wateva526
