Fpv Boost Gauge Question
byi
  • Member For: 18y 7m 27d
Does anyone know how the F6 boost gauge connects to the vehicles engine bay? I have the full wiring loom set for both gauges and the oil pressure sender however is a sender even required for the boost gauge? or is the wiring loom sufficent?
Cheers,
  • Member For: 20y 2m 2d
From the FPV workshop manual it plugs into the Engine Sender HArness for Boost, but there is no mention of the oil pressure.
700_06.pdf
Thank you for that attachment. I'm not too concerned about the oil pressure as I have the sender required for that to operate correctly. So your opinion is that the wiring loom once connected to the engine sensor harness is all that is required for the boost gauge to operate?
Cheers,
  • 9 months later...
  • Inactive Members
  • Member For: 16y 2m 8d
Cheers,
I have just been reading your quote. I have just bought the fpv gauges, pod and wiring harness but I can only see where the oil pressure plugs into this harness. I only own a ba xr6 turbo mk2 where does the boost signal come from.
  • 4 weeks later...
  • 12 years later...
  • New Member
  • Member For: 7y 1m 23d
Hi team,
I'm in the same position to locate the boost sensor that will allow factory gauges to work.
Anyone have pic?
I'm aware of the boost sensor on the intercooler pipe, but I believe this not apart of the gauge wiring system.
Thanks
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 6d
There's a sensor on the BA F6 intercooler itself which screws into the side of it. But you really don't want to use the factory gauges as they suck.
  • 3 months later...
  • New Member
  • Member For: 3y 9m 25d
hey boys I have just got the fpv f6 boost and oil gauges but im looking for a part number for the correct wiring loom can any one plzz assist thanks in advance guy.
  • Site Developer
it comes as a whole thing, so no, you can't just get the loom... and you need an FPV VIN to get the gauges and pod and loom from ford... but long story short, it's much easier/cheaper to run your own aftermarket pod/wiring/gauges and to top it all off they'll all be accurate.
