rhys86 Donating Members 443 Member For: 17y 3m 26d Gender: Male Location: Wollongong Posted 22/05/07 06:20 AM Share Posted 22/05/07 06:20 AM My tuner said I may need to fit colder spark plugs when I get my next lot of upgrades done. He said he uses NGK plugs but could anyone tell me the part number that he would be using if he was fitting colder plugs. Any help would be great Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 17y 11m 5d Gender: Male Location: Sydney NSW Posted 22/05/07 11:41 AM Share Posted 22/05/07 11:41 AM standards are fine mate, re gapped if running higher boost Link to comment Share on other sites More sharing options...
Phoontastic Donating Members 262 Member For: 18y 2m 21d Gender: Male Location: Canberra Posted 22/05/07 12:24 PM Share Posted 22/05/07 12:24 PM standards are fine mate, re gapped if running higher boostI agree. Half the price of the NGKs and just as good. You could try the Motorcraft gas plugs; same part number except for a 7 at the end. Gap is fine for higher boost applications straight out of the box. Link to comment Share on other sites More sharing options...
SAMSXR6T Member 685 Member For: 19y 2m 14d Gender: Male Location: CENTRAL COAST Posted 22/05/07 08:20 PM Share Posted 22/05/07 08:20 PM standards are fine mate, re gapped if running higher boost Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 16y 11m 28d Gender: Male Location: central coast Posted 23/05/07 01:56 AM Share Posted 23/05/07 01:56 AM (edited) he might be useing a plug ment for standard fittment on some other make of car, I did my plugs recently and I spoke to ngk australia to see if was ok to fit f6 plugs into 6t and they said all their plugs designed for xr6t were the same heat range Edited 23/05/07 02:01 AM by our06t Link to comment Share on other sites More sharing options...
rhys86 Donating Members 443 Member For: 17y 3m 26d Gender: Male Location: Wollongong Posted 23/05/07 10:04 PM Author Share Posted 23/05/07 10:04 PM Thanks for your help guys will prob just stick with the standard plug that way I will save some money Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 1m 4d Posted 24/05/07 12:19 AM Share Posted 24/05/07 12:19 AM (edited) I had standard regapped plugs in the car, yeh um changed them out last weekend for a plug the same rating as a phoon plug but gapped to 0.8mm and it made a difference to idle power ect, though plugs could have been on the fritz, but I got a colder plug already gapped for cheaper than I would at Ford, so pending how many km's your car has done perhaps a plug change is just a wise thing to do, rewards are smooth idle and smooth power Edited 24/05/07 12:20 AM by Fat-Tony Link to comment Share on other sites More sharing options...
gu4800 Member 156 Member For: 17y 14d Location: Brisbane Posted 26/05/07 04:09 AM Share Posted 26/05/07 04:09 AM changed them out last weekend for a plug the same rating as a phoon plug but gapped to 0.8mmNGK PFR6BWRX 1996 - 2000 plug. Same plug, same heat, etc, just comes gapped at 0.8mm. Or, BKR6EIX - Iridium version of the above.Others are running this plug with no problems.Dan Link to comment Share on other sites More sharing options...
gu4800 Member 156 Member For: 17y 14d Location: Brisbane Posted 26/05/07 04:58 AM Share Posted 26/05/07 04:58 AM (edited) Just to clarify:NGK Recommended plugs:WRX (96-00) - PFR6BP = PlatinumF = Size (in this case 19mm reach, 14mm thread, 16mm hex)R = Construction (in this case Resistor) 6 = Heat Rating (in this case 6)B = Firing end design feature XR6T (02 +) - FR6EI-11F = Size (in this case 19mm reach, 14mm thread, 16mm hex)R = Construction (in this case Resistor) 6 = Heat Rating (in this case 6)E = Reach (19mm, which is the same as F as above)I = Iridium 11 = 1.1 mm gapSo in short:- Same size thread, seat and head (F and the E)- Same construction (Resistor)- Same heat range (6)- Different gap - 0.8mm for WRX and 1.1mm for XR6- One is Iridium and one is Platinum (although you can get the Iridium version - PFR6B = BKR6EIX*)Why buy new plugs and regap when you can just buy the SAME plug already gapped to 0.8mm?* BKR6EIX Iridium WRX plugBK = 14mm thread and 16mm hex (same as XR6T)R = Resistor (same as XR6T)6 = Same heatE = 19mm reach (same as XR6T)IX = Iridium (same as XR6T - the X means fine wire)Again - same plug, just gapped already to 0.8mm! Dan Edited 26/05/07 04:59 AM by gu4800 Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 1m 4d Posted 26/05/07 03:52 PM Share Posted 26/05/07 03:52 PM NGK PFR6BWRX 1996 - 2000 plug. Same plug, same heat, etc, just comes gapped at 0.8mm. Or, BKR6EIX - Iridium version of the above.Others are running this plug with no problems.DanYep that's the plug, runs fine without a hitch Link to comment Share on other sites More sharing options...
