Iconic Bionic My engine bay is Bionic Donating Members 3,726 Member For: 18y 1m Gender: Male Location: Freeways Posted 15/03/07 12:33 AM Share Posted 15/03/07 12:33 AM Do you reckon if ford machined the inside of the drums it would fix it. The morons cant even adjust it properly one side of the car lifts or squats when I wack the brake on....←You must be still using Dominelli Ford. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 9m 27d Gender: Male Posted 15/03/07 06:02 AM Share Posted 15/03/07 06:02 AM same problem here..lifts at the right when you use it.. nothing happening on the left at all! Link to comment Share on other sites More sharing options...
Tubofords New Member 14 Member For: 5y 2m 27d Posted 01/01/21 08:24 AM Share Posted 01/01/21 08:24 AM (edited) I'm having the same issue, I've adjusted the handbrake according to the manual (wheels drag on 1 click and won't turn on 3 clicks by hand). The handbrake holds well forward (must rev engine to about 2k rpm to get it to move), but rolls backwards under idle. Is there now a fix for this (after 13 years since this thread started)? BA XR6T Edited 01/01/21 08:25 AM by Tubofords Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 01/01/21 09:14 AM Share Posted 01/01/21 09:14 AM If you've adjusted it then tried to move with it adjusted, you've wrecked the adjustment, basically... it's not meant to stop a car from moving, only hold it from starting to move. Adjust it again and if it holds as you let off the brake pedal on an incline testing environment, then you're all good and only apply it once you've stopped unless you need it in an emergency situation. Link to comment Share on other sites More sharing options...
Tubofords New Member 14 Member For: 5y 2m 27d Posted 01/01/21 09:28 AM Share Posted 01/01/21 09:28 AM This is what I did, I adjusted and then applied the handbrake whist stationary. The car starts to roll backwards when I take my foot off the brakes when in reverse. This would be the same as sitting on a hill with handbrake and taking foot off the brake. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 01/01/21 09:38 AM Share Posted 01/01/21 09:38 AM Just do it with the car in neutral on a small incline, to not stress the system unnecessarily and adjust as necessary. Link to comment Share on other sites More sharing options...
Tubofords New Member 14 Member For: 5y 2m 27d Posted 01/01/21 10:39 AM Share Posted 01/01/21 10:39 AM Unfortunately my driveway is about 45deg incline so the handbrake needs to be ultra strong. The park pawl won't last forever I assume. The properly adjusted handbrake doesn't hold on this incline. Link to comment Share on other sites More sharing options...
Tubofords New Member 14 Member For: 5y 2m 27d Posted 03/01/21 09:21 AM Share Posted 03/01/21 09:21 AM I end up fixing the problem, I did a few things so I have no idea what was the actual reason for it working now. - I removed the discs from both back wheels - Sprayed and wiped both the shoe and inner disc with brake cleaner - Scrubbed both shoe and inner disc with emery cloth. The disc was slightly glazed, but still had heaps of wear material left. - The springs that hold the shoe back against the hub assembly weren't attached, the shoe was just free-floating which probably didn't help. I clipped the spring back on to the shoe in all 3 spots. - I adjusted the shoes so there was no drag on one click and equal drag both wheels on one click, then no movement on 3 clicks. - Put everything back together. - Put the car in neutral on a hill and tried the handbrake. Car still rolled backwards easily with 5 clicks. I went back up the hill and let the car roll backwards with the handbrake applied. After each roll the grip got more and more. After about 10 times the car was holding on the hill with only 3 clicks. Car now holds on steep inclines. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 03/01/21 09:35 AM Share Posted 03/01/21 09:35 AM good result Link to comment Share on other sites More sharing options...
