O Trader Member 88 Member For: 15y 5m 14d Posted 30/11/19 09:44 PM Share Posted 30/11/19 09:44 PM On the turbo banjo or the the block supply banjo end ? Is the restrictor in the block supply banjo in the Earl's kit ? Link to comment Share on other sites More sharing options...
Budda New Member 3 Member For: 5y 19d Posted 30/11/19 10:39 PM Share Posted 30/11/19 10:39 PM There is a very small filter in the block end banjo fitting that will need to be removed and you need a small pair of opening cir clip plyers the new kit bolts back on without the small filter the filter is in the bolt not the banjo The new filter in the kit restricts the flow enough Link to comment Share on other sites More sharing options...
O Trader Member 88 Member For: 15y 5m 14d Posted 01/12/19 12:17 AM Share Posted 01/12/19 12:17 AM (edited) Yes, I have already removed the OEM filter which is 30mm long on an FG and also removed the OEM metal supply line and installed an Earls's filter supply line but I was not aware of this restrictor that has been mentioned. I never found one when I removed / installed the lines and fittings so I was asking where this restrictor is supposed to be located 🤔 I have seen oil line kits that have a small orifice opening on the 90 deg turbo end fitting but the Earl's kit that I have did not have it. Edited 01/12/19 12:20 AM by O Trader Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 01/12/19 03:03 PM Share Posted 01/12/19 03:03 PM restrictor. 1 Link to comment Share on other sites More sharing options...
O Trader Member 88 Member For: 15y 5m 14d Posted 01/12/19 10:24 PM Share Posted 01/12/19 10:24 PM Awesome. Thanks for the clarification. Much appreciated Arronm. Link to comment Share on other sites More sharing options...
ilk Is on holiday from communism Member 1,282 Member For: 5y 2m 26d Gender: Female Location: Victoria Posted 20/09/20 12:14 AM Share Posted 20/09/20 12:14 AM Took mine out today, turbo is a lot quieter and runs better. Link to comment Share on other sites More sharing options...
