Mixalis Member 38 Member For: 10y 11m 1d Posted 05/03/19 04:43 AM Share Posted 05/03/19 04:43 AM Hi everyone, going to resurrect this thread. Just purchased a BF Typhoon and have also bought a braided oil supply line kit, will be removing this filter as well. I have read a few times that the process is slightly more complicated in an F6 than it is in an XR6 Turbo. Is it just the oil cooler sandwich plate that's different? Is there anything else that I would specifically need to get or do to perform this on an F6? Cheers guys Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 05/03/19 05:59 AM Share Posted 05/03/19 05:59 AM the difference is in the oil pressure sensor (that is actually for the stock oil pressure gauge) which you have to remove from the top of the oil supply line connector before you can get the connector out at all, so you can't put a socket on it, basically, but you have to hold it with two spanners. 1 Link to comment Share on other sites More sharing options...
Mixalis Member 38 Member For: 10y 11m 1d Posted 05/03/19 06:15 AM Share Posted 05/03/19 06:15 AM Cheers Keith, so from what I understand without looking at this, where others use the deep socket and a spanner, ill have to use two 24mm spanners? I wont be able to use the deep socket until I get the banjo off and I want to take the last fitting off? Thanks for that mate, sounds like a PITA but were already on a roll with pulling this thing apart so might as well do it now before we change oil and oil filter Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 05/03/19 06:27 AM Share Posted 05/03/19 06:27 AM yep... that's basically correct (I can't remember if it's 24 or 22mm, but something like that). It's a bit of a stuff about, but not too difficult - you need to shorten one anyway, so you should have a full-size backup to do the "holding". 1 Link to comment Share on other sites More sharing options...
troyza New Member 1 Member For: 5y 1m 11d Posted 08/03/19 12:26 PM Share Posted 08/03/19 12:26 PM Hi all, I have an 07 TTG and had the oil sensor on the feed line go it fits into the top of the banjo,well what I did was took the sensor out and plugged it with a brass plug so what I want to know is will this affect the oil supply? ,also the harness plug that clips onto the sensor well that broke at the wire that plugs onto the sensor are they a sealed unit?.Any advice is appreciated so thanks in advance. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 08/03/19 11:52 PM Share Posted 08/03/19 11:52 PM Nope, it's fine to just have the plug in there as it won't affect oil supply. Just get a new plug and wiring (from either ford spares or a wrecker) and splice it back in. Link to comment Share on other sites More sharing options...
Budda New Member 3 Member For: 5y 1m 11d Posted 09/03/19 03:54 AM Share Posted 09/03/19 03:54 AM About to put in a Intune motorsports in line filter kit in the oil filter is up the top of the motor easy to get at and easy to clean worth the price Link to comment Share on other sites More sharing options...
O Trader Member 88 Member For: 15y 6m 6d Posted 30/11/19 12:11 PM Share Posted 30/11/19 12:11 PM Do these Falcon Garrett turbo's require oil line restrictors as I have seen some of these after market turbo oil line kits with a restrictor orifice inplace . . . some do some dont. Whats correct ? Link to comment Share on other sites More sharing options...
O Trader Member 88 Member For: 15y 6m 6d Posted 30/11/19 01:10 PM Share Posted 30/11/19 01:10 PM Also where exactly is this Garrett inbuilt restrictor located ? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 30/11/19 02:08 PM Share Posted 30/11/19 02:08 PM yes, they need a restrictor. The stock turbo has a restriction in the oil supply connection banjo fitting. 1 Link to comment Share on other sites More sharing options...
