dalts Member 755 Member For: 17y 10m 23d Gender: Male Location: brisbane Posted 27/12/06 07:21 AM Share Posted 27/12/06 07:21 AM thanks zap f6,did mine today along with the difillipo turbo pipes,makes a nice improvement,took 5 min didint need to take the battery out,just used a long pair of pliers very easythanks lee Link to comment Share on other sites More sharing options...
simonhoare Member 85 Member For: 17y 7m 12d Location: S.A Posted 27/12/06 07:44 AM Share Posted 27/12/06 07:44 AM Just for those who are mechanically challanged, for the battery when disconnecting which terminal do I take of first and which do I put on first when reconnectingcheers←neg of first on last!! 2 Link to comment Share on other sites More sharing options...
BA_XR6Turbo_Ute Member 106 Member For: 18y 7m 13d Location: Sunnybank, brisbane Posted 27/12/06 07:47 AM Share Posted 27/12/06 07:47 AM cheers lads Link to comment Share on other sites More sharing options...
BA_XR6Turbo_Ute Member 106 Member For: 18y 7m 13d Location: Sunnybank, brisbane Posted 28/12/06 04:18 AM Share Posted 28/12/06 04:18 AM (edited) Ok guys got everything done except for getting that baslted little hose offThe clamp had a bit of rust on it so I didn't wanna pull it off otherwise I thought I'd break the hose or something.Put everything back together. I then thought wouldn't it be easier to put a t peice further on on the hose that connects to the boost solenoid and install the t peice of some sort then access would be easier.Just an idea. Perhaps someone more mechincally minded could say if this is a viable solutionI have attached a picture with my ideaEDIT:blue t squiggle is the proposed t peice and red circle is where I thought I could be located. Of course there would be some sort of thing to block the 3rd hole on the t peicefeedback??? Edited 28/12/06 04:20 AM by BA_XR6Turbo_Ute Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 19y 3m 11d Gender: Male Location: In my house Posted 28/12/06 04:32 AM Share Posted 28/12/06 04:32 AM We tried it last night on my mates stock T and it made a difference for sure.Coming on boost earlier in higher gears which is what he said was originally lacking.Cheers fellas Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 2m 4d Gender: Male Location: Sydney Posted 28/12/06 05:59 AM Author Share Posted 28/12/06 05:59 AM I guess you could put a T piece on, but the removal of the hose is easy.Just grab the hose above the clamp and twist 'n pull it straight off.The clamp does not hold the hose on much as there is not a lot of pressure running through the hose.I am glad people are finding this a good maintenance procedure as it will make a noticable difference to the performance. 1 Link to comment Share on other sites More sharing options...
dnicolici Member 7 Member For: 18y 11m 24d Posted 28/12/06 07:12 AM Share Posted 28/12/06 07:12 AM Hi guys this is my first post on here, so I hope you will go easy on me. Iv ahd a T for about 6 months now and love the car!! I tried this but the other end of the hose came of, im not sure where it goes. Could some on instruct me on where it fits or could someone take a picture. it would be even grater help. Thanks alot 1 Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 19y 3m 11d Gender: Male Location: In my house Posted 28/12/06 07:59 AM Share Posted 28/12/06 07:59 AM Hi guys this is my first post on here, so I hope you will go easy on me. Iv ahd a T for about 6 months now and love the car!! I tried this but the other end of the hose came of, im not sure where it goes. Could some on instruct me on where it fits or could someone take a picture. it would be even grater help. Thanks alot←There are 2 hoses that run on to the solinoid.Is it the top hose or the bottom? Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 18y 9m 11d Gender: Male Location: OZ Posted 28/12/06 08:14 AM Share Posted 28/12/06 08:14 AM Ok guys got everything done except for getting that baslted little hose offThe clamp had a bit of rust on it so I didn't wanna pull it off otherwise I thought I'd break the hose or something.Put everything back together. I then thought wouldn't it be easier to put a t peice further on on the hose that connects to the boost solenoid and install the t peice of some sort then access would be easier.Just an idea. Perhaps someone more mechincally minded could say if this is a viable solutionI have attached a picture with my ideaEDIT:blue t squiggle is the proposed t peice and red circle is where I thought I could be located. Of course there would be some sort of thing to block the 3rd hole on the t peicefeedback???←haaa I'm calling you Mr squiggle from now on!!!!good idea, but once you get the hose of once it's not too bad after.My hose was on so tight that is was actually hard to get back on and I took half the car apart to do it, so I can see why some people have problems. Also the solenoid will unclip from the bracket once you see how the clip works. A small problem with my T (6sp man) is that when cruising and I put my foot down, sometimes the car doesn't react and then suddenly hits boost and takes off. This may be linked to the solenoid and I'm monitoring if the car does it again.Great post Zap...... next a guise to manifold torquing. I'll do this in the next month and take some pics. Cheers all!! Link to comment Share on other sites More sharing options...
MYWPN Donating Members 554 Member For: 18y 9m 17d Gender: Male Location: Bendigo Posted 28/12/06 08:20 AM Share Posted 28/12/06 08:20 AM does not make much difference unless you have a factory alarm.If you do, make sure the ignition is on then remote the + terminal first to avoid the alarm going off.←should always disconnect your negative terminal first Link to comment Share on other sites More sharing options...
