qwigybo Member 288 Member For: 17y 11m 16d Location: bendigo home of SFA Posted 07/04/07 03:02 AM Share Posted 07/04/07 03:02 AM what program/settings are you using to get the video to display on the iccbeen playing with powerstrip on my laptop but unable to get a steady picture as yet Link to comment Share on other sites More sharing options...
MrBean Member 400 Member For: 17y 11m 13d Location: Melbourne Posted 20/04/07 11:21 PM Share Posted 20/04/07 11:21 PM Hello,I am having similar issues with the quality of video display on the LCD - the normal Ford ICC display pictures are high-quality, but the moment you use external input, it starts to shiver and dance, stripy etc.What I am doing is using high-quality vga monitor cable, snipping the end d-sub connectors, and replacing Ford's "sh*tty" 1/2 screened datacable coming from the LCD unit.I should finish this cable, and installation tomorrow, and will feedback on the difference in quality.Br,MrBean Link to comment Share on other sites More sharing options...
ritzy Member 119 Member For: 17y 3m Gender: Male Location: Lysterfield, Melbourne Posted 29/04/07 01:38 PM Share Posted 29/04/07 01:38 PM What extra parts do you need for external input for both Audio and video.Plus if I wanted an amp what is required.Thanks Link to comment Share on other sites More sharing options...
veczar Gold Platinum Member Member 1,081 Member For: 19y 9m 24d Gender: Male Location: Victoria Posted 05/07/07 03:56 AM Author Share Posted 05/07/07 03:56 AM what program/settings are you using to get the video to display on the iccbeen playing with powerstrip on my laptop but unable to get a steady picture as yetPM me mate about this one.Hello,I am having similar issues with the quality of video display on the LCD - the normal Ford ICC display pictures are high-quality, but the moment you use external input, it starts to shiver and dance, stripy etc.What I am doing is using high-quality vga monitor cable, snipping the end d-sub connectors, and replacing Ford's "sh*tty" 1/2 screened datacable coming from the LCD unit.I should finish this cable, and installation tomorrow, and will feedback on the difference in quality.Br,MrBeanAre you useing a laptop or PC. If its a laptop then it shouldn't shiver and dance while the power pack is unplugeed (ie running on laptop battery). If its a PC how are you powering it? 240v mains, inverter or 12v PSU?What extra parts do you need for external input for both Audio and video.Plus if I wanted an amp what is required.ThanksA lot! more information please. What are you planning to put on the input? XBOX, computer, dvdplayer? Link to comment Share on other sites More sharing options...
MrBean Member 400 Member For: 17y 11m 13d Location: Melbourne Posted 16/07/07 12:29 AM Share Posted 16/07/07 12:29 AM (edited) Are you useing a laptop or PC. If its a laptop then it shouldn't shiver and dance while the power pack is unplugeed (ie running on laptop battery). If its a PC how are you powering it? 240v mains, inverter or 12v PSU?I am using 2 different PC's, one a Apple MacMini, then a Commell-based system.3 Different DC-DC startup/shutdown controllers, M2-ATX, Carnetix P1900, and Carnetix P2140.Same result - problem is the Factory LCD powered by raw DC from battery, and no good filter implemented. I use a Xenarc 7" LCD powered by the secondary output on the Carnetix controller, and no problem - if I power the Xenarc with the same raw 12Vdc from the battery, I have the same issues.At least in my case it is the quality of the power causing an issue.So, I am now permanently running the Xenarc, and off the secondary dc-dc controller output.Just thought I'd clear that up. Edited 16/07/07 12:31 AM by MrBean Link to comment Share on other sites More sharing options...
veczar Gold Platinum Member Member 1,081 Member For: 19y 9m 24d Gender: Male Location: Victoria Posted 24/07/07 01:35 AM Author Share Posted 24/07/07 01:35 AM At least in my case it is the quality of the power causing an issue.So, I am now permanently running the Xenarc, and off the secondary dc-dc controller output.Just thought I'd clear that up.Have you tried running ALL grounds accociated with the system directly back to the battery neg terminal. That is what I had to do do get rid of the dodge powered screen issue. Link to comment Share on other sites More sharing options...
MrBean Member 400 Member For: 17y 11m 13d Location: Melbourne Posted 24/07/07 06:03 AM Share Posted 24/07/07 06:03 AM Have you tried running ALL grounds accociated with the system directly back to the battery neg terminal. That is what I had to do do get rid of the dodge powered screen issue.All my grounds re: Carputer are directly connected to bat (-)Anyway, as stated above, it is working fine powering LCD from the Carnetix, which is anyway the best way to go (filtered to all components), so I have no interference from the alternator.No worries, I am sure someone else would find a different way that works too, for me this was the easiest and cleanest since I had the Carnetix controller anyway, so might as well put it to good use Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 16y 10m 24d Gender: Male Location: Melbourne Posted 24/07/07 06:25 AM Share Posted 24/07/07 06:25 AM Tim are you able to tell me what type off amp the premium sound package has, I wanna see if it is worth running a 12inch pioneer sub with it till I got the cash for an aftermarket amp, I'm having no luck at all finding any useful info on the net or the site, I think if anyone will know you will. Cheers Dillon p.s. kick @rse set-up Link to comment Share on other sites More sharing options...
veczar Gold Platinum Member Member 1,081 Member For: 19y 9m 24d Gender: Male Location: Victoria Posted 06/08/07 02:39 AM Author Share Posted 06/08/07 02:39 AM Tim are you able to tell me what type off amp the premium sound package has, I wanna see if it is worth running a 12inch pioneer sub with it till I got the cash for an aftermarket amp, I'm having no luck at all finding any useful info on the net or the site, I think if anyone will know you will. Cheers Dillon p.s. kick @rse set-upYeh I started doing that also. There are many options and also three topics covering the subject PM Sent. Link to comment Share on other sites More sharing options...
