TurboDewd FG Falcon fan! Member 1,452 Member For: 20y 9m 13d Gender: Male Location: Canberra Posted 20/10/06 01:37 AM Share Posted 20/10/06 01:37 AM (edited) I really like the look of what appears to be a white or silver (can someone clarify which?) instrument cluster inthe Territory these days.Would it be feasible to put that in a Falcon? Can it be done without resetting all the counters?I think white guages in a black dash look so much better. Edited 20/10/06 01:38 AM by TurboDewd Link to comment Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 19y 6m 17d Gender: Male Location: Melbourne, Victoria Posted 20/10/06 02:34 AM Share Posted 20/10/06 02:34 AM The TT Ghia has a silver (brush stainless) look, but it is a high end instrument cluster (ie car with climate control). Therefore only suitable for use in an XR with climate control. The stock territory has a standard black facia type cluster.I'm not sure if the territory type cluster will go straight in a BA, but should be OK in a BF. I think there is a difference between BA and BF ??? Maybe someone can clarify. Also you can't reset the the odometer beyond 100km travelled. Same for any cluster.Robin. Link to comment Share on other sites More sharing options...
TurboDewd FG Falcon fan! Member 1,452 Member For: 20y 9m 13d Gender: Male Location: Canberra Posted 20/10/06 03:22 AM Author Share Posted 20/10/06 03:22 AM you post is make me sad mans... Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 19y 11m 25d Gender: Male Location: Brisbane Posted 20/10/06 05:54 AM Share Posted 20/10/06 05:54 AM (edited) They don't 'appear' to be different between BA & BF - have been wrong once before though.Also with regards to changing clusters, doesn't the dealer set the new one to the existing odometer reading?EDIT: Have you tried ASL Logistics Turbodude? They might be able to answer/help with regards to the facia Edited 20/10/06 05:56 AM by tab Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 20y 11m 24d Gender: Male Location: Victoria Posted 20/10/06 05:59 AM Share Posted 20/10/06 05:59 AM Also with regards to changing clusters, doesn't the dealer set the new one to the existing odometer reading?Yes, but that ability is lost after the cluster odometer reaches a set reading as Robin said. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 19y 11m 25d Gender: Male Location: Brisbane Posted 20/10/06 06:06 AM Share Posted 20/10/06 06:06 AM Also with regards to changing clusters, doesn't the dealer set the new one to the existing odometer reading?Yes, but that ability is lost after the cluster odometer reaches a set reading as Robin said.←On the new one? Wouldn't it have to be fitted with a WDS handy in any case? Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 20y 11m 24d Gender: Male Location: Victoria Posted 20/10/06 06:15 AM Share Posted 20/10/06 06:15 AM If you want your original km's installed onto the new cluster you need to do it before the lock out distance is reached.The odometer is changed with a WDS. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 19y 11m 25d Gender: Male Location: Brisbane Posted 20/10/06 07:40 AM Share Posted 20/10/06 07:40 AM Sorry, that's what I was trying to say I assume any cluster changes would be done by a ford dealer, therefore one would assume access to a WDS, hence changing it before the new odometer even reaches 1km.See - clear as mud Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 20y 11m 24d Gender: Male Location: Victoria Posted 20/10/06 08:15 AM Share Posted 20/10/06 08:15 AM There's no reason why you couldn't fit it yourself.You only need a dealer to set the odometer. Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 19y 7m 10d Gender: Male Location: Mildura Posted 20/10/06 03:22 PM Share Posted 20/10/06 03:22 PM surely you could get the brushed aluminium ghia facia from somewhere??are any companies making the facia inserts yet for the falcons? stuff like this has been out in commodores for years! Link to comment Share on other sites More sharing options...
