XR06T Silver Donating Members 4,146 Member For: 18y 9m 28d Gender: Male Posted 22/01/07 12:07 AM Share Posted 22/01/07 12:07 AM best of luck mate..let us know how you go! Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 19y 7m 11d Gender: Male Location: Mildura Posted 22/01/07 12:09 AM Share Posted 22/01/07 12:09 AM just going over this one again because it is really starting to piss me off at the lights.the idle hunts between 650 and 700 rpm and when braking up to a set of lights with the clutch in drops as low as 250 then jumps to 1k then back down again..if it was an auto it would stall for sure.checked the tb a month or so ago and its clean as a whistle.any new ideas on this one people?←that's EXACTLY what my old NA ute done... when getting off the gas for a set of lights it nearly stalls, then hunts for the revs just jumping and dipping... took it to ford twice they foundf nothing. so I took it for a drive until it done it again and I took it strait to ford WITHOUT TURNING THE IGNITION OFF, get them to bring the computer thing out and check it. guarntee'd it will bring up a TPS error. they will replace on warranty.just dont turn the car off, or it wont show. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 9m 28d Gender: Male Posted 22/01/07 12:15 AM Share Posted 22/01/07 12:15 AM thanks trough..no warranty for me so I will find out how much I should be charged for one.any idea anyone? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 27d Gender: Male Location: Perth Posted 22/01/07 01:48 AM Share Posted 22/01/07 01:48 AM I got told by ford that they where either $80 or $180 i cant remember which.... If you can get a part number i can try and get a better price through conventrys.. I've been told be several ford mechs that the only way to change it is when the car is hot because the little tiny screws that hold to sensor on are thread lock and the heat in the throttle body softens the the thread lock so you can get them out without stripping the screw... Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 19y 7m 11d Gender: Male Location: Mildura Posted 23/01/07 02:32 AM Share Posted 23/01/07 02:32 AM make sure u try the computer check first... but it definately sounds the same prob as I had. very frustrating I know. Link to comment Share on other sites More sharing options...
aphexer Member 29 Member For: 18y 11m 9d Location: Eastern Suburbs, VIC Posted 24/01/07 02:01 AM Share Posted 24/01/07 02:01 AM ok, cars back from 60km service performed by reputable local mechanic. had the three maintenance issues addressed - lubricate electronic solenoid, tighten exhaust manifold and clean throttle body.Throttle body was filthy, exhaust manifold was slightly loose and electric solenoid was in need of WD40 :D did a full oil & filter change.idle now is near perfect, doesn't hunt thru the revs any more. however, due to the carbon buildup in the throttle body it has contaminated the oxy sensor and is throwing up error codes. doesn't affect idle as such, but will affect fuel economy. $330 for a new one dang!hope this helps anyone with a similar problem! Link to comment Share on other sites More sharing options...
simonhoare Member 85 Member For: 17y 7m 13d Location: S.A Posted 24/01/07 02:26 AM Share Posted 24/01/07 02:26 AM I got told by ford that they where either $80 or $180 I cant remember which.... If you can get a part number I can try and get a better price through conventrys.. I've been told be several ford mechs that the only way to change it is when the car is hot because the little tiny screws that hold to sensor on are thread lock and the heat in the throttle body softens the the thread lock so you can get them out without stripping the screw... ←you use a soldering to heat the heads of the screws up or careful use of a heat gunwhen the engine is colder. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 9m 28d Gender: Male Posted 31/01/07 12:56 AM Share Posted 31/01/07 12:56 AM would a blocked oxy sensor cause any other problems through the rev range?I think mine is the tps because occasionally when cruising the car will drop or pick up speed without me moving my foot..everyone think tps is my problem? Link to comment Share on other sites More sharing options...
