Roley94 Member 114 Member For: 11y 1m 16d Gender: Male Location: Perth Posted 10/09/13 08:02 AM Share Posted 10/09/13 08:02 AM So I just had my car tuned a few weeks ago and today I decided to put the trumpet on my dual port bov just for fun and realized at idle the valve was open about 5mm, if I tighten it up so its closed at idle will it effect my air fuel ratios? Link to comment Share on other sites More sharing options...
Jamesy 88 New Member 22 Member For: 12y 11m 13d Gender: Male Location: Eastern Suburbs, Melbourne Posted 01/12/13 10:18 PM Share Posted 01/12/13 10:18 PM I've had myTurbosmart Dualport Kompact BOV installed for a little over two years now fully vented. During this time it has worked like a dream, however over the past couple of weeks I have noticed it mainly doesn't open at all and when it does it's only when the cars at full running temp and smashing high boost. I have shortened the vac line as much as possible to avoid kinks, just wondering if there is any sort of maintenance required for this BOV's? Any help would be good Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 21y 5m 11d Gender: Male Location: Dé·jà vu Posted 01/12/13 11:34 PM Share Posted 01/12/13 11:34 PM Lube. Link to comment Share on other sites More sharing options...
Jamesy 88 New Member 22 Member For: 12y 11m 13d Gender: Male Location: Eastern Suburbs, Melbourne Posted 02/12/13 12:13 AM Share Posted 02/12/13 12:13 AM Thanks for the suggestion mate, ill try some oil. Either that or put my brothers new BOV on to try and eliminate that all together Link to comment Share on other sites More sharing options...
Ropata94 Member 20 Member For: 10y 6m 2d Gender: Male Posted 02/12/13 10:57 PM Share Posted 02/12/13 10:57 PM Well if that's the case I got a plumb back on one side and theyll never know what setting its on really unless they pull my BOV out coz u cant really see it and cops arent that smart... Hi dave I just ordered the Turbosmart kompact dual port 25mm aswell, and am putting it In today Can you give me any heads up? I'm not really hands on with this kind of stuff, and also my cars runnig the standard 6psi stock boost, will I notice a noise change? Thanks heaps Link to comment Share on other sites More sharing options...
Dootboy Member 7 Member For: 10y 10m 19d Gender: Male Location: Bathurst NSW Posted 06/04/14 10:50 AM Share Posted 06/04/14 10:50 AM Holy sh*t. I just realised after reading this post I have installed my turbosmart BOV backwards..... Car was making crazy turbo flutter and has for last 3 months. Is there anyway to tell if I've done damage???? Funny thing is it was initially making the loud swoosh but stopped after installing plazmaman CAI?............ Any info would be awesome cheers guys. Link to comment Share on other sites More sharing options...
paps fg F6 New Member 3 Member For: 11y 19d Gender: Male Posted 29/03/15 12:23 PM Share Posted 29/03/15 12:23 PM Just purchased a kompact dual port series bov to suit my fg f6. Motor is stock and running .9bar boost. My bov came with a pink spring. I found it was opening way to early causing boost to vent out. I have fitted all 6 supplied washers to spring, tightened all the way and retested, is better but still not holding boost to .9 bar. Also prefer the tututu sound over psssshhhht. Do I need a stiffer spring? Or can I put more washers? Link to comment Share on other sites More sharing options...
BoostedG6E Member 105 Member For: 6y 3d Gender: Male Location: Melbourne Posted 30/12/22 04:58 AM Share Posted 30/12/22 04:58 AM Hey all, currently upgrading to a G42 turbo and am wondering if I will need to run a Turbosmart Gen V Race Port Blow off Valve, I see some cars run them but unsure if it is necessary or not. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 30/12/22 05:04 AM Share Posted 30/12/22 05:04 AM a BOV isn't necessary at all, if you don't want one... but if you want to have proper BOV operation at extra boost pressure then a higher quality one is ideal... if you're not changing the boost level, no need to change the BOV you're currently using if it works fine. Link to comment Share on other sites More sharing options...
BoostedG6E Member 105 Member For: 6y 3d Gender: Male Location: Melbourne Posted 30/12/22 05:07 AM Share Posted 30/12/22 05:07 AM it will definitely be making more boost, im not currently runnining one at the moment its blocked off. Link to comment Share on other sites More sharing options...
