XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 20y 9m 17d Location: Sydney Bronx :) Posted 31/05/06 12:06 AM Share Posted 31/05/06 12:06 AM Hi Chooka, Yes, the system does come with the Cat.Jordak, all I know about the cats is that they are Hi flow metalic substraight, one a 3" the other a 3.5". I do not have specs on flow rates etc. Link to comment Share on other sites More sharing options...
Chooka THE Member Donating Members 1,210 Member For: 18y 8m 23d Gender: Male Location: Melbourne Posted 31/05/06 12:26 AM Share Posted 31/05/06 12:26 AM Hi Chooka, Yes, the system does come with the Cat.Jordak, all I know about the cats is that they are Hi flow metalic substraight, one a 3" the other a 3.5". I do not have specs on flow rates etc.←Thanks, XR6ISMIf that's the case it's a fantastic buy!!!Chooka Link to comment Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 20y 9m 17d Location: Sydney Bronx :) Posted 31/05/06 02:42 AM Share Posted 31/05/06 02:42 AM Hi Chooka, Yes, the system does come with the Cat.Jordak, all I know about the cats is that they are Hi flow metalic substraight, one a 3" the other a 3.5". I do not have specs on flow rates etc.←Thanks, XR6ISMIf that's the case it's a fantastic buy!!!Chooka←It is and you will get a power increase also. When these systems were tested on my car by Bestmufflers (who then send them on to Xforce to start production of the kits), my car gained 14rwkw when standard with the 3" system. The only draw back is that this system will not run more then 270rwkw. The 3.5" system has no problems with holding 300+ rwkw. Link to comment Share on other sites More sharing options...
ford number 1 Donating Members 602 Member For: 19y 7m Gender: Male Location: N/W Sydney Posted 31/05/06 03:12 AM Share Posted 31/05/06 03:12 AM I know of a car with the 3inch xforce system and its running 290rwkw.. Link to comment Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 20y 9m 17d Location: Sydney Bronx :) Posted 31/05/06 05:33 AM Share Posted 31/05/06 05:33 AM I know of a car with the 3inch xforce system and its running 290rwkw..←I guess it depends on who's dyno and how it was tuned. With the 3" test system on Spiro's dyno the car made 270rwkw before Spiro said I need a bigger exhaust system. At this stage Chris (from Best mufflers) made up the 3.5" system which when put on the dyno jumped straight to 290. With some extra tuning we left it on 303rwkw.You can find out info on:http://www.bestmufflers.com/Information/Cu...yno_Results.htmRegzDean Link to comment Share on other sites More sharing options...
ford number 1 Donating Members 602 Member For: 19y 7m Gender: Male Location: N/W Sydney Posted 31/05/06 05:36 AM Share Posted 31/05/06 05:36 AM it was tuned by spiro on his dyno Link to comment Share on other sites More sharing options...
FSIX Member 566 Member For: 18y 5m 4d Posted 31/05/06 07:05 AM Share Posted 31/05/06 07:05 AM I picked up a 7 month old APS exhaust for $1000, flows 70% better than the standard xr6t stock exhaust. Link to comment Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 20y 9m 17d Location: Sydney Bronx :) Posted 31/05/06 01:52 PM Share Posted 31/05/06 01:52 PM it was tuned by spiro on his dyno←This is interesting, cause Spiro managed 270 from mine before I needed the system changed. Good to know that its capable of more, thanks for that info mate. Link to comment Share on other sites More sharing options...
Guest Guests Posted 31/05/06 08:21 PM Share Posted 31/05/06 08:21 PM it was tuned by spiro on his dyno←This is interesting, cause Spiro managed 270 from mine before I needed the system changed. Good to know that its capable of more, thanks for that info mate.←the 3" xforce with cat replacement has seen 400rwkw and better everyday driveabilitythe 3.5 when available with the twin dump and metal cat not the current normal cat made to look like a metal cat will be awsome!!!! Link to comment Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 20y 9m 17d Location: Sydney Bronx :) Posted 31/05/06 11:44 PM Share Posted 31/05/06 11:44 PM it was tuned by spiro on his dyno←This is interesting, cause Spiro managed 270 from mine before I needed the system changed. Good to know that its capable of more, thanks for that info mate.←the 3" xforce with cat replacement has seen 400rwkw and better everyday driveabilitythe 3.5 when available with the twin dump and metal cat not the current normal cat made to look like a metal cat will be awsome!!!!←DW.....even though Xforce may make the split pipe used in my car, we have scrapped the split pipe for the 4" pipe that's currently on the car. Spiro has confirmed it has had a positive effect on the car when it was last tuned and there was a power gain. RegzDean Link to comment Share on other sites More sharing options...
