bob^ Member 170 Member For: 20y 4m 26d Location: Geelong Posted 23/01/06 07:43 AM Author Share Posted 23/01/06 07:43 AM Yeah mate, it's a complete stand alone headunit.Tucked up underneath the factory deck, is a plug for the antenna. That comes out easily to plug into the new deck.Behind the fuse panel is a plug ofr the carkit that has your ground, constand, and accessories. I used the cigarette lighter wiring though for ground and accessories, and ran a new constand power lead. That is because I have a distrobution block under my drivers seat so that wasn't a big job. Make sure any new power wires that you run are FUSED!!!The factory speaker wires were cut in the looms in the kick panels, and I joined my wire to them. I couldnt run new wires into the doors because my hands are too fat, so there is about half a meter of the factory stuff. The rest is my own wiring. Link to comment Share on other sites More sharing options...
shockF6 Member 478 Member For: 18y 5m 25d Location: Melbourne Posted 23/01/06 11:09 AM Share Posted 23/01/06 11:09 AM Spot on.I tried getting a PC running on the factory screen with the VGA out, RGB in, but I couldn't get the refresh rates right, no matter what I did. There is a video card called ArcadeVGA which will let you do it no worries.I'm going to try the TV out on my PC now that I have the adaptor, and I'll see how that looks.you will probably need a circuit to correctly merge the H & V syncs to use on the ICC. even then you will need a program like power strip to get your video card outputting the correct resolution and refresh to simulate NTSC Link to comment Share on other sites More sharing options...
bob^ Member 170 Member For: 20y 4m 26d Location: Geelong Posted 23/01/06 11:35 PM Author Share Posted 23/01/06 11:35 PM The video card I was using was capable of doing composite sync. I think all the ATI cards can do it. I was using power strip too, but I was unsuccessful. Link to comment Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 20y 6m 25d Location: Canberra - ACT Posted 26/01/06 10:46 PM Share Posted 26/01/06 10:46 PM Built a very neat custom harness for ms700 that makes use of that Box - these boxes are great becuase you can make Sat-Nav friendly installs work without too much fuss. In ms700s car all the gear is mounted under front passenger seat, with a single cable running up to the ICC that handles Input selection, video signals and IR (if wanted).... Just a little ciggy pack sized box up between the SatNav and the ICC plug.A. Link to comment Share on other sites More sharing options...
richyrich Member 11 Member For: 18y 2m 20d Posted 19/04/07 03:59 AM Share Posted 19/04/07 03:59 AM Built a very neat custom harness for ms700 that makes use of that Box - these boxes are great becuase you can make Sat-Nav friendly installs work without too much fuss. In ms700s car all the gear is mounted under front passenger seat, with a single cable running up to the ICC that handles Input selection, video signals and IR (if wanted).... Just a little ciggy pack sized box up between the SatNav and the ICC plug.A.have the converter set up.I have a picture but it is rolling.Or flikering..I have set my machine to output ntsc.What have I done wrong Link to comment Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 19y 5d Gender: Male Location: New Zealand Posted 19/04/07 07:11 AM Share Posted 19/04/07 07:11 AM I have been looking for something like that so I can add a reverse camera to enable me to tow my closed in race car trailer - and be able to see back (particularly when reversing).But... $300ish is quite expensive just to convert the signal isnt it? surely someone does some cheaper versions?I have searched everywhere for RGB cameras so you dont need a converter - but with no luck, anyone else?Standard RCA connected cameras (reverse, night time etc etc ) are cheap. Link to comment Share on other sites More sharing options...
