.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 1m 11d Gender: Male Location: Perth Posted 31/03/14 06:55 AM Share Posted 31/03/14 06:55 AM Haha good wet weather tyres will help, but you still need to respect the torque of these cars. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 1d Gender: Male Location: Perth Posted 31/03/14 06:56 AM Share Posted 31/03/14 06:56 AM TyresTyre pressures Wheel alignment Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 10y 10m 29d Gender: Male Location: NOR Perth Posted 31/03/14 07:11 AM Share Posted 31/03/14 07:11 AM YES!!!! finally rocking the multiquote thanks to google chrome Haha good wet weather tyres will help, but you still need to respect the torque of these cars.Makes sense I suppose....still rekon better tyres should help a bit? plus as stated the times when its scary ... I'm not even using the right pedal at all lol TyresTyre pressuresWheel alignmentIs that a question for me? or a statement? I assume statement lol .... but FYI tyres as mentioned GY EF1 D5 and Falken Azenis PT-722, 40psi front and 37psi rear, wheel alignment as done by Bob Jane (maybe sh!thouse?)...I would assume they do it to Ford specs or something? Link to comment Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 13y 6m 3d Gender: Male Location: Work Posted 31/03/14 07:16 AM Share Posted 31/03/14 07:16 AM im running Nitto Invos 245/35/20 on the front and Yokohama Earth 1 (Ref http://global.yokohamatire.net/products/earth1.html ) 275/30/20 on the rear. Nittos are 260 tread wear (softest I could find). I think the fronts (bottom pic) could have used a little more air/more camber.... maybe, Aaron or Luke would have a better idea. Rears are just feathered from spinning. Again, Tirerack.com is an awesome site for getting info on everything tyre related. Below page will explain tread wear/traction rating/speed rating etc. http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=48 Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 10y 10m 29d Gender: Male Location: NOR Perth Posted 31/03/14 07:42 AM Share Posted 31/03/14 07:42 AM (edited) So do you rate the earth 1 tyres? clearly not so much by the sounds of your first post? (plus me being a noob I cant see any damage to the tyre...as they look in better condition than the invos? lol) ...I just did a google search and found the post by taleb tyres on these....$199 each is insanely cheap for 20's ?I thought yokohama is supposed to be the sh!t....but maybe like every tyre manufacturer, there is the cheaper average tyres and the more expensive better tyres?Thanks for the link! (I think I may have already read it before...its where I actually discovered UTQG/Treadwear lol....but maybe I have to re-read and some new info will appear to me) I have a feeling that its not as simple as low UTQG = more grip Does your car try to slide out at 30-35kmph when turning right at a roundabout? Maybe its just a normal thing and I'm just being a b!tch lol ***Forgot to add that my car is stock! ... maybe I shouldn't be increasing power any time soon... I can handle it in the dry but in the wet I drop nuts lol Edited 31/03/14 07:45 AM by PTR_NITRO_FG Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 11y 1m 29d Gender: Male Location: Perth Posted 01/04/14 10:24 AM Share Posted 01/04/14 10:24 AM Hey anyone know where I can take old car oil to recycle around midland area? I also have a big container full of a mix of coolant, oil and transmission fluid (I know it was dumb I just had no where to put it all and was in a rush) will they take that? Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 4m 30d Gender: Male Location: Probably above atmospheric pressure Posted 01/04/14 11:12 AM Share Posted 01/04/14 11:12 AM Mine ends up at Coppin Rd tip in Mundaring :( They have a big hole you dump it in 20L per visit...but of course we have a tip pass due to living in the area. Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 7m 2d Gender: Male Location: Perth, WA Posted 01/04/14 12:52 PM Share Posted 01/04/14 12:52 PM You local council tip will have an oil disposal facility. You should be able to dump the oil and containers for free.Probably best to ring your local council and enquire. Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 11y 1m 29d Gender: Male Location: Perth Posted 01/04/14 01:05 PM Share Posted 01/04/14 01:05 PM Is coppin rd the one where you have to have a tip pass?Cheers guys Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 4m 30d Gender: Male Location: Probably above atmospheric pressure Posted 02/04/14 11:52 AM Share Posted 02/04/14 11:52 AM Yeah it sure is. We get 2 trips a year or something. Link to comment Share on other sites More sharing options...
