hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 20y 5m 21d Gender: Male Location: Melbourne Posted 16/12/03 01:54 AM Share Posted 16/12/03 01:54 AM I'm thinking of getting the centre muffler re-installed. I was initially pretty happy with having it removed it but its getting louder - on startup it drones and sounds sh%t - I've also noticed that it seems to bog down especially when giving the car a bootful when going up a hill or hooking into curves, seems to be more lag than I remembered. Definately feels too rich in some circumstances. Been there done that, nothing but slowly compounding power loss. I ended up trying hot dogs, same same, Finally went to a 2.5 stainless centre muffler $550 or $650 and a K&N filter got my power and sound back. Hope you kept the centre muffler they are nearly $400. I ended up replacing the whole exhaust with a twin 2.5 stainless and would have saved plenty of money and greif if I had done that in the first place. As far as cutting out centre muffler is concerned, from my experience. No No No No No No No. Re-install the factory muffler and you'll notice your torque come back. Link to comment Share on other sites More sharing options...
Guest Guests Posted 16/12/03 02:28 AM Share Posted 16/12/03 02:28 AM Mine is fine,power still there.. it would be loud in a shed on start up. Link to comment Share on other sites More sharing options...
Phantomxr6 Member 452 Member For: 21y 3d Gender: Male Location: Razorback NSW Posted 16/12/03 02:34 AM Share Posted 16/12/03 02:34 AM mines fine too, no drone & a definate power increase. Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 2m 19d Gender: Male Location: Sydney Posted 16/12/03 03:23 AM Share Posted 16/12/03 03:23 AM My car is booked in for Monday at the exhaust shop to get this done, maybe now I should cancel......Hammer, I have a full XR8 exhaust system from cats back, if I am convinced enough not to go ahead you can have the XR8 system (its the same centre section as a turbo) Link to comment Share on other sites More sharing options...
hammer007 Donating Members 149 Member For: 21y 1m 16d Location: Canberra Posted 16/12/03 03:44 AM Share Posted 16/12/03 03:44 AM I've still got the centre exhaust - its not a quick bolt back in as they didn't flange it the way I asked them to when it was cut out.Mick - thanks for the offer - I've got it booked in on Thursday for City Exhaust to have another look at it. When we went on the cruise to Batemans Bay I'd only just had it fitted and thought it was OK but over time I'm less convinced. I'll be bringing the car into work on Thursday so if you like I could bring it out to Mitchell and you can hear what it sounds like a few months after removal.cheersMartin Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 2m 19d Gender: Male Location: Sydney Posted 16/12/03 04:08 AM Share Posted 16/12/03 04:08 AM What I would like to do hammer is give you the XR8 centre section, and try your pipe section on my car? Just unbolt it, flange to flange. I can then take "your" pipes and my T down to Gas Tune one night, and have a dyno session and see how we go.....Or I can just stick to my original plan, and do all that myself! :lol: Let me know what your plans are for your centre section. Link to comment Share on other sites More sharing options...
hammer007 Donating Members 149 Member For: 21y 1m 16d Location: Canberra Posted 16/12/03 10:25 PM Share Posted 16/12/03 10:25 PM MickI'll have a better look underneath tonight when I get home - not 100% sure that the bolt-in / bolt-out will work but happy to give it a go.Martin Link to comment Share on other sites More sharing options...
bkofoed Member 90 Member For: 21y 1m 7d Posted 17/12/03 12:49 AM Share Posted 17/12/03 12:49 AM I've done the centre muffler removal also, and nothing but pleased with the results.Hypnodoc- I remember in an earlier post you said the mid range was flat etc after the center muffler removal and you were looking for other options. Then in another post later you mentioned that the dyno you were running on was found to be faulty? Are the two events related?Also, conspiracy theory, does the ECU learn and detune for the free flowing exhaust over time Link to comment Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 21y 25d Location: Wellington NZ Posted 19/12/03 03:59 AM Share Posted 19/12/03 03:59 AM Also, conspiracy theory, does the ECU learn and detune for the free flowing exhaust over time I have heard that the T ECU does this too. Alot of guys found the same thing with Expensive Daewoo V8's when upgrading them. Big power gains at first then slowly back to stock. I think I heard that anything up to 10 maybe 15 KW is ok after that the ECU knobbles things. Go with the piggy back computer. Link to comment Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 20y 5m 21d Gender: Male Location: Melbourne Posted 19/12/03 06:06 AM Share Posted 19/12/03 06:06 AM Hypnodoc- I remember in an earlier post you said the mid range was flat etc after the center muffler removal and you were looking for other options. Then in another post later you mentioned that the dyno you were running on was found to be faulty? I think I definately began to lose power when I chopped out the centre muffler. The Dyno that was used to first install the UNICHIP still gave a twenty kW lower reading after it had been fixed. If I had to do it all again I definately wouldn't remove the centre muffler. I have come a long way since then, changed injectors etc. Took delivery this morning of a PWR intercooler, twice the standard size with only 1.5lb restriction. Now I can only stare at it until FORMAZ re-open on 12th Jan. With this in, a bigger BOV, and stronger wastegate actuator, it should blow 15lb of boost quite happily. I have a twin 2.5 stainless Manta centre muffler at the moment, getting rear bit fitted on the 5th Jan with high flow cat. Had an xcellent cold air mod fitted today (see post). So 400kW (motor) is the target for Jan. Link to comment Share on other sites More sharing options...
