xr6t83 Member 16 Member For: 19y 4m 7d Location: Melbourne Posted 15/12/04 11:51 PM Share Posted 15/12/04 11:51 PM Just had it gassed yesterday, they told me to take it back to ford!has anybody had any problems with there aircon units, im a bit skeptical that its just a faulty hose or something, at first I was told its just a slow leak, after getting it re-filled yesterday theres only a minimal decrease in air temp compared to the day before when it was only blowing hot air!Any info would greatly be appreciated!Cheers Mark Link to comment Share on other sites More sharing options...
Jaymz Member 190 Member For: 20y 4m 11d Location: Noosa Posted 16/12/04 12:00 AM Share Posted 16/12/04 12:00 AM On my EL I had a stone chip on the condensor and the gas was leaking from there took a while to identify it, BA's however don't have the condensor located like the EL's so shouldn't get hit by anything. They can run a coloured gas through the system to identify most leaks, suggest they do this as on a new car you shouldn't have to put up with warm aircon. Mine is fantastic especially in these 36 degree days we have been having. Link to comment Share on other sites More sharing options...
cqae Member 229 Member For: 20y 5m 14d Posted 16/12/04 01:36 AM Share Posted 16/12/04 01:36 AM the 'colored' gas can be either used during the charge process & is contained in the gas or can be injected to a system at the end of gassing. It is a UV dye that glows under a UV light to make leak detection easier, although it has its pros & cons. A major leak like it seems you have-leaked out over night should be easy to find, how ever a non cold system could be more thatn just low on gas. there are other things that can do this, so AC guages usually need to be connected to check pressures & performance.If there is a leak that large it really should have been found during the regass or prior to that when the systen is vacced down & left stand. Unfortuneatley lots of places skip a lot of the testing & just shoot some gas in & worry about the details later.an air con specialist should ba able to handle any of these situations easily. Link to comment Share on other sites More sharing options...
