Cashie Donating Members 663 Member For: 21y 2m 2d Gender: Male Location: Perth Posted 14/11/04 05:14 AM Share Posted 14/11/04 05:14 AM Does anyone know the colours of the speaker wires, which wire is poitive and which is negative etc? Link to comment Share on other sites More sharing options...
Mondie Firm Member Donating Members 2,924 Member For: 21y 4m 28d Location: Adelaide Hills Posted 14/11/04 06:07 AM Share Posted 14/11/04 06:07 AM Typically in home audio red or white is +ve, and black or green -ve. Not sure if the same wire colurs are used in car audio though Link to comment Share on other sites More sharing options...
Flukey Seriously Flukey Member Donating Members 4,354 Member For: 20y 8d Gender: Male Location: Melbourne Posted 14/11/04 06:32 AM Share Posted 14/11/04 06:32 AM One will be different, either by colour or will have a marking like a line on it. That will be the positive. If it is a new install, it doesnt matter, as long as the same colored/marked cable goes to the same terminal at each end. Otherwise, your speakers will be out of phase (one would push, one would pull) and it would sound terrible. Link to comment Share on other sites More sharing options...
Cashie Donating Members 663 Member For: 21y 2m 2d Gender: Male Location: Perth Posted 14/11/04 06:52 AM Author Share Posted 14/11/04 06:52 AM I think I worked it out, each side has one wire with a black trace, I assumed this was the negative. I read on ff that it was the positive but I am fairly certain it is not, I just wanted confirmation. Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 21y 5m 18d Gender: Male Location: South Coast NSW Posted 14/11/04 07:19 AM Share Posted 14/11/04 07:19 AM Sometimes the stripe is negative speaker terminal and other times it is for the positive - there is NO standard unfortunately. As long as it's a 'floating earth' system (as most four-speaker systems are these days) it won't matter just as long as you are consistent in the way you connect them all up.And sometimes, with regard to what Luke has said, if the speakers are facing directly towards each other from opposite sides then you may get better sound by wiring them out of phase - so they don't both push at the same time, which can sound very bad. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,807 Member For: 20y 6m 25d Gender: Male Location: Townsville Posted 19/11/04 07:53 AM Share Posted 19/11/04 07:53 AM XR8 Ute,If you need info on what wires are what send a PM to eXtreme as he owns the BA manual and has helped me out considerably by emailing the info I need.Brett. Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 7d Gender: Male Location: Perth, WA Posted 19/11/04 08:09 AM Share Posted 19/11/04 08:09 AM I will check for you when I get home and confirm! Link to comment Share on other sites More sharing options...
FORDTECH Member 383 Member For: 20y 9m 28d Location: On the edge Posted 19/11/04 08:15 AM Share Posted 19/11/04 08:15 AM The only wires in the manual that actually show the polarity are the sub woofer wires. Link to comment Share on other sites More sharing options...
Cashie Donating Members 663 Member For: 21y 2m 2d Gender: Male Location: Perth Posted 19/11/04 08:25 AM Author Share Posted 19/11/04 08:25 AM I worked it out last night, the wires with the black trace are the negative wires.Thanks all. Link to comment Share on other sites More sharing options...
Ronald99 New Member 0 Member For: 4y 10m 2d Posted 27/05/19 08:35 AM Share Posted 27/05/19 08:35 AM I got an xr8 manual and I can’t find the speaker wires On 19/11/2004 at 5:23 PM, bjc said: XR8 Ute, If you need info on what wires are what send a PM to eXtreme as he owns the BA manual and has helped me out considerably by emailing the info I need. Brett. Link to comment Share on other sites More sharing options...
