aniken I don't suffer from insanity; I enjoy every minute of it Donating Members 4,316 Member For: 21y 4m Gender: Male Location: Sydney, south west Posted 19/04/04 10:21 AM Share Posted 19/04/04 10:21 AM If you accelerate faster, then more force is being applied to move your vehicle, hence more force is required to stop it.But the car doesn't weigh any more. Why would you need more force to stop it from any given speed? You might have a problem with standard brakes if you typically accelerate fast in heavy traffic: more acceleration + same reaction time = reduced 'margin for error' = a need for more brake power to offset the reduction in your 'margin for error'. Or, you could just not drive fast in heavy traffic. Link to comment Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 20y 5m 24d Location: Sydney Posted 19/04/04 10:38 AM Share Posted 19/04/04 10:38 AM But the car doesn't weigh any more. Why would you need more force to stop it from any given speed? You don't , as I said in the previous post. Both modded and non-modded cars are speed limited by the ECU. BUT, there are two factors to consider; firstly the modded car accelerates much faster, using much more force to do so (given that it has greater power and torque). To stop this faster accelerating car, you need a proportionate amount of force. This force is eliminated (in the form of a reduction in speed of a car) by dissipation of heat into the discs of the car's brakes(and the capacity of the brake calipers to provide the compression power to the discs). Obviously, to use standard brakes to dissipate so much extra force you will run into problems (fade, capacity to provide enough force resistance etc)The second factor is that more powerful brakes will pull a vehicle up a lot quicker than standard brakes under identical acceleration for modified/unmofified vehicles. Link to comment Share on other sites More sharing options...
teebone Member 183 Member For: 20y 5m 18d Location: South of Melbourne, near the sea Posted 19/04/04 11:10 AM Share Posted 19/04/04 11:10 AM But the car doesn't weigh any more. Why would you need more force to stop it from any given speed? You don't , as I said in the previous post. Both modded and non-modded cars are speed limited by the ECU. BUT, there are two factors to consider; firstly the modded car accelerates much faster, using much more force to do so (given that it has greater power and torque). To stop this faster accelerating car, you need a proportionate amount of force. This force is eliminated (in the form of a reduction in speed of a car) by dissipation of heat into the discs of the car's brakes(and the capacity of the brake calipers to provide the compression power to the discs). Obviously, to use standard brakes to dissipate so much extra force you will run into problems (fade, capacity to provide enough force resistance etc)The second factor is that more powerful brakes will pull a vehicle up a lot quicker than standard brakes under identical acceleration for modified/unmofified vehicles.This has got me thinking about whether there are any implications for the Brake system performance and "legality" with respect to ADR 31. Power and torque don't appear to be a consideration. Only vehicle mass (which I presume doesn't change much by adding a piggyback ecu?), the testing speed, deceleration rates and pedal effort - which is interesting. APS and others don't appear to have made any reference to this in the past - only emissions & noise ADRs - so I'm assuming this interpretation is correct ? Link to comment Share on other sites More sharing options...
100% Premium Donating Member Donating Members 641 Member For: 20y 6m Gender: Male Location: If it says ONLINE below, in front of the computer, if not, tearin' up some bitumen! Posted 19/04/04 11:54 AM Share Posted 19/04/04 11:54 AM We'll that may be the case, but his car is probably far less dangerous than a modified T with 330 kw at the wheels and standard crappy brakes So do you think stopping my car from 100km/h while accelerating at full throttle requires more force than is required to stop from 240km/h? At what acceleration/speed does the force required to stop exceed that required from 240km/h which the brakes are designed for?Anyone into physics here?Sorry to continue the hijack! Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 20y 11m 8d Gender: Male Location: At the lights, waiting for you. Posted 19/04/04 03:48 PM Share Posted 19/04/04 03:48 PM Geea, I support you in the comments you have made. You have made educated choices in the modifications you have done and in my opinion made the best decisions for your T. Keep up the good work, I'm sure you get satisfaction doing it, much as I do. Not all people have the time or skills (nor the desire) to do the research to pick the better "stuff" mixing and matching so sometimes they have to take a stab in the dark, rely on someones advice and hope for the best ; but pay a HUGE premium for it also. You can look at it the other way also. Sometimes if its just a one off thing you want to do and your not that way inclined as a DIY person you are better off paying someone whatever it cost to do it and do what you do best to pay it off. Geea. Link to comment Share on other sites More sharing options...
Dr Z Member 378 Member For: 20y 1m 29d Posted 19/04/04 08:14 PM Share Posted 19/04/04 08:14 PM We'll that may be the case, but his car is probably far less dangerous than a modified T with 330 kw at the wheels and standard crappy brakes So do you think stopping my car from 100km/h while accelerating at full throttle requires more force than is required to stop from 240km/h? At what acceleration/speed does the force required to stop exceed that required from 240km/h which the brakes are designed for?Anyone into physics here?Sorry to continue the hijack!I offered an intuitive explanation in the legality thread HERE, but since 100% wants a physics explanation.. As many of us may recall from our high school physics, the equation which relates the distance travelled to the quantities of acceleration and velocity is: Distance = (1/2 x Initial Velocity ^ 2) / Accelerationwhere in our case of wanting to stop a car from some initial velocity: Distance = braking distanceInitial Velocity = initial velocity at which brakes are appliedAcceleration = deceleration required to bring car to a final velocity of 0Note: The better the braking mechanism, the greater the deceleration (which was my point in the legality thread about 100% getting better brakes!)This formula can be verified anywhere on the internet, like HERE for example (the example I used in the legality thread).In addition, as I mentioned in the legality thread:In terms of braking in a car:* Thinking distance is directly proportional to speed * Braking distance is directly proportional to the square of the speed So:Total stopping distance = reaction distance + braking distanceTo highlight the dangers of initial velocity (speed) assuming reaction time on average is 1.5 seconds and deceleration is 10m/s^2, consider this:At 60 km/hr:Reaction distance = 60000m / 3600 seconds x 1.5 seconds = 25 metresBraking distance = (1/2 * (60000/3600)^2)/10 = 13.9 metresTotal stopping distance = 38.9 metresAt 65 km/hr:Reaction distance = 65000m / 3600 seconds x 1.5 seconds = 27.1 metresBraking distance = (1/2 * (65000/3600)^2)/10 = 16.3 metresTotal stopping distance = 43.4 metresDifference of 5 km/hr = 4.5 metres (43.4 - 38.9) which is a 12% increase in stopping distance! That is definitely enough of a difference to avoid or minimise damage to yourself or someone else!..and what about at 240 km/hr?Reaction distance = 240000m / 3600 seconds x 1.5 seconds = 100 metresBraking distance = (1/2 * (240000/3600)^2)/10 = 222.2 metresTotal stopping distance = 322.2 metresHmm, that is nearly 1/3 of a kilometre stopping distance!Is it relevant to braking distance what throttle was applied to get to 240km/hr? No!Finally, how about the stopping distance for the fastest XR6T to date?...the APS Phase III run at Avalon clocked at 307 km/hr:Reaction distance = 307000m / 3600 seconds x 1.5 seconds = 127.9 metresBraking distance = (1/2 * (307000/3600)^2)/10 = 363.6 metresTotal stopping distance = 491.5 metresWow, that is nearly 1/2 of a kilometre stopping distance!Conclusions: 1. The initial acceleration used to get a vehicle up to a certain velocity has ZERO effect on braking distance, though in the absence of higher anticipation in reaction times, it may significantly increase reaction distance, therefore total stopping distance.2. Since initial velocity (speed at which brakes are applied) and deceleration capability (quality of braking power) are the only 2 variables that affect braking distance, then how much throttle is applied to get to that initial velocity is IRRELEVANT except for the purposes of reaction distance...which is why I advised 100% to get better brakes! 3. If FoMoCo rates standard brakes as sufficient braking power to stop a vehicle from 240km/hr then it is this initial velocity that matters irrespective of what throttle is applied to get there. In short, it is speed and NOT the acceleration to reach that speed which is the determinant for braking distance. Anyone feeling tempted to quote Newton's Second Law relating to Force, Mass, Acceleration etc in an attempt to refute these conclusions is referred HERE to dust off some Physics 101 cobwebs. Finally, just to get the thread back on track, I personally would definitely choose APS over any other modification supplier for their:1. Legality compliance: which is also necessary for insurance duty of disclosure requirements so insurance companies cannot walk away from claims made on illegal cars.2. Reputation reliability: since there are so many APS modified Ts out there going stronger than ever!3. Component durability: where components are made from the best sourced materials and configured as a total package by qualified engineers.4. Power consistency: given that the different Phase kits deliver high levels of power consistently, so power can be smoothly accessed at all throttle applications.Brutebogart, or anyone else, no doubt there would be many volunteers who would happily test drive you in their APS Phase I, II or III modified cars so you can see what they are so thrilled about! Safe and happy driving...Dr Z. Link to comment Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 20y 5m 24d Location: Sydney Posted 19/04/04 10:07 PM Share Posted 19/04/04 10:07 PM Thanks for the bible on physics there, DR Z, but you missed the point made in my previous posts.The fact that a modified car accelerates much quicker than a standard T means that it gets to a level of speed at a much shorter time. This means, for example, it could take off at a set of lights and reach 100kmph in less than 1-2 seconds than a non-modified T. Of course, this means it also does it over a shorter distance, therefore meaning that in general the modified T is greater of far greater speeds than a non modified car over normal driving conditions (available distance in giving traffic situations).Because of this greater speed capability, you would need more force to be applied to pull up the car in equally limiting distance conditions (ie citty traffic driving), which neccesitates the fitting of better brakes than the standard T has.I've been in a car that can hit 100ks in under 5 seconds (probably closer to 4) and then had to hit the brakes hard to stop the car in a very short distance. It is without a doubt that the standard T's brakes could not cope with this situation, and that's exactly why I decided to change mine (although im still not happy with them given the increased ability of my car).FoMoCo may say that the T's brakes can stop the car at 240's but over what distance. FAR greater than a car with better brakes is an obvious conclusion.In regards to your final 4 points, it would be good to note that competing companies to APS also offer these sollutions. Point 1 may be a little difficult, but possible with companies like Chiptork Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 20y 8m 2d Gender: Male Location: NSW Posted 19/04/04 10:08 PM Share Posted 19/04/04 10:08 PM The problem I have with the standard brakes is that with the extra power I able to get to a higher speed between corners and because I get to the speed quicker the brakes have less time to cool down before they have to try and stop the tank again, so yes I think a brake upgrade is a good thing. The car wqas fine before to drive through kangaroo valley now it has a huge shudder after the first few corners. Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 21y 3m 26d Gender: Male Location: Sydney Posted 20/04/04 01:50 AM Share Posted 20/04/04 01:50 AM Dr Z,I understand that you are trying to assist people.However, in my opinion there are a number of flaws in your arguments. The formulas that you quote are quite well known.I have no issue regarding you’re assertion (quoting from other references) that braking distance is related to reaction time and braking distance, which is obviously correct.The main flaw in the arguments is the assumption that acceleration is constant.To be specific:Re your conclusion 1.“The initial acceleration used to get a vehicle up to a certain velocity has ZERO effect on braking distance, though in the absence of higher anticipation in reaction times, it may significantly increase reaction distance, therefore total stopping distance.”The rate of acceleration when you attempt to brake has a major impact on braking distance. The higher the power of the car the higher will be the RATE of acceleration, rather than acceleration being constant. During the reaction time (assuming it is constant) you will travel much further if you are undergoing increasing acceleration rather than constant acceleration. Constant acceleration is assumed in most calculations, largely for the sake of simplicity. In this case it is incorrect.Conclusion 2.Since initial velocity (speed at which brakes are applied) and deceleration capability (quality of braking power) are the only 2 variables that affect braking distance, then how much throttle is applied to get to that initial velocity is IRRELEVANT except for the purposes of reaction distance...which is why I advised 100% to get better brakes!This conclusion assumes zero acceleration and therefore constant velocity, clearly not the case.Dr Z, when you draw conclusions using an “air of authority”, I’d suggest you make sure you really understand your subject. If you want a demonstration of increasing acceleration and deceleration I would be only too happy to scare the hell out you. Anyone feeling tempted to quote Newton's Second Law relating to Force, Mass, Acceleration etc in an attempt to refute these conclusions is referred HERE to dust off some Physics 101 cobwebs. Did you actually read the reference that you quoted? It actually refers to the f=ma equation, (via “Work is the force times the distance, and since force is the mass times acceleration”) which IS Newtons 2nd law, and which is very relevant to braking. The higher the force generated by the vehicle, the higher will be the force required to stop the vehicle. The better the brakes, the greater the force that can be put on the vehicle in terms of deceleration to bring it to a stop.Your unqualified recommendation of APS is remarkable, given that you don’t own a turbo, you have no previous turbo experience or experience with modified cars, nor have you ever dealt with that company before. How would possibly know about component durability, and the capability of the components to last over time. The guys running APS Phase 3 cars have no idea if their motors will last 2 years. In my case my motor was pulled apart, and block defects were found, that without rectification, would have caused problems down the track. Please be careful about making comments in areas where you have no expertise or practical experience, as it is very easy to mislead people.Brian Link to comment Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 20y 11m 25d Gender: Male Posted 20/04/04 02:26 AM Share Posted 20/04/04 02:26 AM "the Rate of Acceleration" would someone explain it clearly to me maybe I'm simple ..... but I thought there was a relationship between time and distance that could be explained by two things (I) the velocity at any point in time and (ii) the change in the velocity from a previous point in time (acceleration) ..... so .... isn't acceleration constant at any given time ?the rate of acceleration is a really interesting concept but it is difficult to apply the to such a variable object as a car .... to accelerate .... you use the pedal on the rightbutonce you brake ..... you use the pedal in the middle .... the laws of physics come into play that relate to the velocity of the car at the time of the initial contact with the brake pedalsmoke and mirrors ... but maybe I'm too simple to understand this, but I do know that it I don't use the pedal on the right and the pedal in the middle at the same time when I'm doing 307km/hr .... and if I did (and lived), then maybe the double derivative of velocity may come into play .... cause as soon as you take your hoof of the right pedal ... there is only an instant of constant acceleration .... and that is a fact Link to comment Share on other sites More sharing options...
