F6 R Spec
    Brisbane
  1. If you are thinking of putting a tow bar on your F6, this might be useful. Since I bought my F6 R Spec, I have been wanting to put a tow bar on it. But was concerned about the finish around where the bar protrudes through the rear bumper. After speaking to a few of the FPV dealers here in Brisbane, the common answer I got was “FPV do not make a kit for the F6, can get one for the GT, but not the F6.” “We have put XR6 ones on F6’s and just put the black edge trim around the hole and they look okay”. Well after a little searching and some help from Phoon Hoon, I have tracked down the Ford Part number for a towbar kit specifically for the F6. BAF 19A009FA This kit includes the bar, the tongue and the plastic end caps to put around the cut out in the bar. Kit sells for about $360.00 + fitting. The only other thing you might need is the wiring harness; this is a must if you have reverse sensors fitted. The factory harness will disable the sensors when a trailer is connected. Hope this is of use to someone out there.
  2. Hi, Just a little I idea I have. Would it be possible to install the front drive system from a Territory under a Falcon/Typhoon? I have had a breif look at how to do it, and without pulling the car apart and accuratley maesuring and trialing things, it seem possible. Just want to know if anyone has considered this or if any one has done it. P.S. Just to make things harder, I would like to keep the Tremec 6 Speed. Any thoughts appreciated. Rob
