Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 16y 7m 18d Gender: Male Location: Adelaide Posted 17/06/09 12:20 PM Share Posted 17/06/09 12:20 PM Well every one is keen so here is a right up on HOW TOill add pics next time I do one Grab a Beer and Read INTIRLY before starting0.) set heater to hot and vents to face and then disconnect battery1.) raise seat up and unscrew 3 hand brake bolts on the drivers side to get hand brake away from console- it clips to console so when loose lift it and move to drivers side to clear console.2.)pull gear stick surround UP and off3.) unscrew 2 console sides with phillips head- 1 screw a side and remove4.) move both seats forward and unscrew 8mm gutter bolts in both sides of rear of console5.) seats back6.) undo 4X 8mm gutter bolts in top of console next to selector and 1X phillips head to loosen console7.) undo 2X phillips holding cig lighter mount in and remove, disconnecting wiring8.) undo 2X phillips holding front of console to dash9.) pull hole console up from rear, if still tight some have 2X clips under carpet in center console storage area(move to side to disengauge)10.)remove console from car11.) beer12.) take top of ICC using flat screwdrive of the like lifting from rear until it unclips13.) remove 1X screw from behind14.) under ICC disconnect arial plug(black) and 4X plug connectors from ICC starting left and working right( bit tricky may need a light and mirror to figure out the clips)15.) undo 4X 8mm screws from the sides 2 a side and pull ICC forward until it is clear of the dash- MOVE CAREFULLY AND STORE UPRIGHT16.) remove lower steering shroud 3X phillips head screws from the bottom17.) disconnect 4/5X plug connectors going to colomb18.) undo 1X 10mm bolt in bottom of colomb holding steering shaft to steering rack left of brake pedal(if it spins use a 13mm spanner to hold otherside)19.) undo 4X 10mm Bolts holding upper section of colomb to dash and remove intire colomb from car(do this with steering centered)20.) remove fuse box cover and use a screw driver to "pry" the bonet release down and towards front of car to unclip21.) remove A pillar covers by pulling away from pillar at the top and working down until off on both sides.22.) in top center of dash remove small 6" cover from dash near windscreen using a pik etc and loosen allen key bolt- dont remove just loosen(6mm from memory)23.)on both sides of dash, remove side panels by prying off, dont worry 1 clip each side will break but it doesnt matter, it can hardly be helped.24.) on both sides pull kick panels away from sides, manipulating them so u have acess to the wiring plugs(they wont break they are very flexible)25.) dissconect 4ish plugs on both sides and pull white plug mount from kick panel area(ull no what I mean) it needs to be forced out as the sh*t plastic clips hold it in 26.) left hand side needs arial disconnected, pul black outer clip doen and pull other half to disconnect it.27.)undo the long 10mm bolt in the bottom of center console area28.) while in the area on the pass side is a plug infront of that bolt for the srs module, black plug with white housing, pull towars pass side to disconnect29.) undo the 10mm bolt nere clutch pedal area that holds metal bracket to firewall30.) undo the 1X 10mm bolt either side that is right in nere the top door hinge and loosen right off till it dangels in the door hinge area31.)undo the 2X 10mm bolts either side that hold the dash in32.) with help from mate pull the dash forward from the center and once it clears the selector, hand brake and firewall work it out the passanger door with out scratching anything .ONCE OUT: Beer33.) disconnect him module floor vent control rod(steel) -HIM is grey module on left side of heater box- rod has a yellow clip to disconnect34.) disconnect 3X wiring plugs to module(4 if dual zone)35.) unscrew 3X screws that hold module in 2 in left side and 1 under screwed to fire wall36.)carefully remove module, manipulating it away from the 3 rods it controls( they r flexible dont be scared(black blue and green I think))37.)remove 6X phillips from very top of heater box and remove that panelIF REPLACING HIM STOP HEAR, FIT NEW HIM AND REFIT DASH- Id replace rod to be safe as its cheap as38.) remove 6X phillips from front of box39.) gentelly pull front down(bottom will still be joined)40.) u should be able to clearly see if the rod is broken now as if it was in tact the HIM would be hard to egt out as rob would be still engauged to it.( the plastic drive gear in the HIM can be pushed out to the pass side to disengauge the rod if it is intact and your just doing the HIM)41.) remove the broken rod by slowly working it out, making sure u suport all 4 flap hinge points as they are prone to break.a mate is handy now! u dont wanna flex the flaps just slide the rod straight out to the left. (if dual zone u will have 2 short rods an extra step is required, remove the servo motor on the drivers side and slide your extra rod out the drivers side)42.) fit the new rod(rods) with the same care to remove43.)once your happy with the rod fitment, making sure the flap edges(bushes) are located in the heater box sides, reassemble the box44.) once box is re assembled fit the HIM with the gear drive pushed left to the disengauge position45.) refit HIM allowing the control rods to fit to the flaps they opperate corectly.46.) lift the heater flaps u just fixed up so they are in the full hot postition(up and forwassd so heater core is visible) and then push the HIM drive gear right so it engauges the rod( dont worry if it doesnt line up perfect the HIM will self test and align its sefl anyway.47.) REFIT in reverse order the DASH etc48.) remomber to refit the ICC connectors in reverse of removal, replug the lower plugs left to right.49.) when its all back together connect the battery and opperate as usual the HIM should self test and adjust itself as required.50.) if u fitted a New HIM take the car to a sparky or ford to have it programmed to your carBEERThe HIM is the same part regardless of model variant it is just coded differantly.ill post part numbers soon but any ford dealer should know them:)If Mods wanna make this sticky I can modify when I do picks next time I do one that will make it much easier than starting from scratchif I left anything out please let me no:)tools requiredphillips head screw driver8mm Socket10mm Socketpik or flat screw driver6mm allen keymaybe an adjustable rench to remove shifter if manual10mm spanner(battery) Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 2m 16d Gender: Male Location: SW Sydney Posted 17/06/09 12:31 PM Share Posted 17/06/09 12:31 PM Legend Mike! I especially like step number 11... Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 19y 11m 29d Gender: Male Location: Brisbane Posted 18/06/09 12:04 AM Share Posted 18/06/09 12:04 AM Good work Mike. Definitely worth every cent of the $350 cashie Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 18y 10m Gender: Male Posted 18/06/09 01:33 AM Share Posted 18/06/09 01:33 AM thanks for posting this mike, some pics would be VERY handy! Link to comment Share on other sites More sharing options...
nifty Lost Member Donating Members 134 Member For: 15y 8m 18d Gender: Male Location: Perth Posted 18/06/09 08:49 AM Share Posted 18/06/09 08:49 AM Thanks for that Mike, really appreciate the effort you went to, Well Done. No wonder it costs so much (it's for all the beer needed to work properly)cheers. Link to comment Share on other sites More sharing options...
mercuryturbo Oh look.... a real car, with no hair dryer Donating Members 1,724 Member For: 17y 8m 13d Gender: Male Location: Fear and Loathing in Callala Bay Posted 18/06/09 08:56 AM Share Posted 18/06/09 08:56 AM (edited) Nice write up mate. Wish you were in Sydney, looks like my dash is coming out very soon. Edited 18/06/09 08:57 AM by mercuryturbo Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 20y 8m 4d Gender: Male Location: Zombie Birdhouse Posted 18/06/09 09:06 AM Share Posted 18/06/09 09:06 AM Rootster will offer his assistance , no payment required. awww I will let him keep his posting rights Link to comment Share on other sites More sharing options...
lowfutura Enforcer Donating Members 520 Member For: 15y 6m 14d Gender: Male Location: Brisbane Posted 18/06/09 12:24 PM Share Posted 18/06/09 12:24 PM Well Done Mate,and I was Freaking because I'm going to pull my instrument panel cluster out.Cheers Link to comment Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 16y 7m 18d Gender: Male Location: Adelaide Posted 19/06/09 09:45 AM Author Share Posted 19/06/09 09:45 AM dude, to pul the cluster out, lower to colomb and undu the three screws undfe it and remove bottom schroud, pull the top schroud up and u will c 2 phillips head screws holding the cluster cover in, undo them and the top u and ull b sweet Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 20y 7m 18d Gender: Male Location: Southern Highlands NSW Posted 26/06/09 10:37 PM Share Posted 26/06/09 10:37 PM You'll never guess what I'm up to today 2 cores in 2 years farking tops hey :banghead: Link to comment Share on other sites More sharing options...
