Inconsistent New Member 1 Member For: 5y 8m 15d Posted 04/08/18 12:07 AM Share Posted 04/08/18 12:07 AM Ok so I’ve got a spare BF e-gas engine with bugger all km’s on it, and a spare BF turbo head. You can obviously see where I’m going with this here. Who’s done this build before? Thinking of just throwing the head on, running it exclusively on a safe E85 tune and see how the high compression goes. Dump the engine into a Ute and have a bit of fun. Stock turbo/injectors too. Are there any suppliers that offer thicker head gaskets to reduce the compression slightly? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 04/08/18 01:43 AM Share Posted 04/08/18 01:43 AM with stock injectors you won't want to be running E85. It'll run. Just get a turbo motor head gasket and some bigger injectors and fuel pump etc for the E85 flow you'll want to run to keep the compression issues away. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 04/08/18 02:54 AM Share Posted 04/08/18 02:54 AM I did something like this and had to take a lot of timing out of the low load areas. It still drove pretty good. I also had to change it a bit on boost but not as much as you'd think. Iirc it comp tested at 230 or 240. Then I turned it up to 19psi, broke a ring land and almost ripped a piston in half horizontally. If you can tune it to remove timing from where it needs it then go for it. If you don't it'll be knocking constantly and pulling heaps of timing even with less than normal, gentle driving. You could probably run a 50/50 mix of 98 and e85 but you'd need to do your research and work out whats going to work for you. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 04/08/18 05:40 AM Share Posted 04/08/18 05:40 AM (edited) Higher comp ONLY if you are running E85 or race fuel OR you need to pull lots of timing. Compression needs to be worked out NOT guessed. PLUS you want forged pistons really>>> Edited 04/08/18 05:42 AM by arronm Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 4m 1d Gender: Male Location: North West Hot Hell,VIC Posted 04/08/18 08:28 PM Share Posted 04/08/18 08:28 PM What sort of power did that e-gas engine make on 19psi Puff ? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 05/08/18 02:11 AM Share Posted 05/08/18 02:11 AM I put the data into virtual dyno and it came back as 410rwkw. Link to comment Share on other sites More sharing options...
