Benji81 New Member 15 Member For: 5y 10m 2d Posted 09/06/18 02:37 AM Share Posted 09/06/18 02:37 AM Going to replace valve springs in my bf so we can turn it up a bit Looking at plasmaman are these good ? Thanks benno Link to comment Share on other sites More sharing options...
Renton Member 151 Member For: 5y 11m 23d Gender: Male Location: Perth Posted 09/06/18 04:00 AM Share Posted 09/06/18 04:00 AM Crow is the only way to go. Many threads on it, and speak to any tuner. That's what they recommend Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 09/06/18 04:24 AM Share Posted 09/06/18 04:24 AM Neg plazmaman have a new spring that's replaced a generic version about 8 months ago now and they’re really good , Atomic do different spec springs also that are brilliant Crows are good but also have rocker to retainer clearance touch issues that’s well documented Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 09/06/18 05:17 AM Share Posted 09/06/18 05:17 AM The issue sometimes occurs, and it's only when you use crow retainers. I have that setup. No issues in my car. Link to comment Share on other sites More sharing options...
shaness8 Member 89 Member For: 14y 7m 25d Gender: Male Posted 09/06/18 09:04 AM Share Posted 09/06/18 09:04 AM I wouldn’t recommend the plazmaman spring with high boost pulling mine out What the difference between standard and crow retainer Can you use crow spring 1809 with standard retainer Link to comment Share on other sites More sharing options...
Benji81 New Member 15 Member For: 5y 10m 2d Posted 09/06/18 09:30 AM Author Share Posted 09/06/18 09:30 AM https://www.independentmotorsports.com.au/1808-24-ford-ba-bf-fg-6-cyl-turbo-spring Will these ones do the trick Aiming for 300rwkw Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 09/06/18 10:12 AM Share Posted 09/06/18 10:12 AM (edited) Yep perfect . Yes 1809 with stock retainers. Crow retainers are thicker and have a 1mm off set. Installed height and seat pressure is the same with 1809 stock or crow retainers Edited 09/06/18 10:48 AM by arronm Link to comment Share on other sites More sharing options...
Renton Member 151 Member For: 5y 11m 23d Gender: Male Location: Perth Posted 09/06/18 12:53 PM Share Posted 09/06/18 12:53 PM (edited) 3 hours ago, Benji81 said: https://www.independentmotorsports.com.au/1808-24-ford-ba-bf-fg-6-cyl-turbo-spring Will these ones do the trick Aiming for 300rwkw Also have a look at vpw.com.au if you are going for the Crows. I got mine for $289 delivered to Perth. Edited 09/06/18 12:54 PM by Renton Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 10/06/18 12:27 AM Share Posted 10/06/18 12:27 AM 15 hours ago, shaness8 said: I wouldn’t recommend the plazmaman spring with high boost pulling mine out The current Plazmaman valve springs can handle 23psi and 500rwkw without any issues at all old ones definitely not Link to comment Share on other sites More sharing options...
