XR6Twannabe Member 21 Member For: 11y 2m 23d Posted 10/05/18 11:40 PM Share Posted 10/05/18 11:40 PM Hi guys,I just purchased a BF II XR6t which came with 20" Simmons and 275/30ZR20 tyres on the rear (245 front).The inside of the rear wheel and tyre seem very close to the chassis/suspension, to the point I can barely fit a finger between it.I'm thinking I need to roll the guards and apply some offset but not sure what the best amount of offset would be for this car and wheel/tyre set up?I was thinking of leaving the front as is, or would it be wise to offset the front also?Lastly - when people say "+22 offset", is this referring to millimetres? Thanks in advance. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 11/05/18 03:55 AM Share Posted 11/05/18 03:55 AM (edited) We ran that size on a BF with 20 x 10 , clearance was 2mm to the rim/control blade, never touched. Dont stress. The higher the number +mm (offset) the closer the wheel sits to the inside of the car. Edited 11/05/18 03:56 AM by arronm Link to comment Share on other sites More sharing options...
XR6Twannabe Member 21 Member For: 11y 2m 23d Posted 12/05/18 06:32 AM Author Share Posted 12/05/18 06:32 AM ah, thanks for clarifying.. so using something like a spacer actually provides negative offset.. so even though the wheel and tyre are only a few mm from the control blade, would there be any other benefit of applying negative offset? more grip? better looking stance? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 12/05/18 07:27 AM Share Posted 12/05/18 07:27 AM Yep, a spacer takes away offset numbers. Nope, no benefit other than how it "looks". But comes with a bunch of potentially bad negative side effects like instability, increased wear, illegality etc. People usually use spacers to run wheels that don't actually fit to start with. Link to comment Share on other sites More sharing options...
