Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 24/04/18 11:46 AM Share Posted 24/04/18 11:46 AM 3 hours ago, JETURBO said: rocker cover bolts go into cam caps, it is possible to pull the caps and re drill/tap them to suit a new bolt That's what he said pretty much 2 hours ago, Gun40t said: Yep seems the rattle gunnned the hell out of them Yeah fark knows why if true. That's gotta be the stupidest thing next to the pull out method. Anyways all the good advice has been given. Hope you get it sorted mate. 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 24/04/18 11:55 AM Share Posted 24/04/18 11:55 AM 6 in the caps. 2 in the front. Are the front 2 OK. Were they stripped before the shop work. Did they even remove the R/C cover. It maybe not what you think... Link to comment Share on other sites More sharing options...
Gun40t Member 98 Member For: 6y 7m 27d Posted 24/04/18 12:05 PM Author Share Posted 24/04/18 12:05 PM I cant put it down to anything else there was metal coming out with the bolts when I removed them( no I didnt strip them) I removed them only with a 3/8 10mm socket. And I would use my torque wrench to retention to specs. What do you suggest is happening? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 24/04/18 12:19 PM Share Posted 24/04/18 12:19 PM Did the shop remove the R/C cover Link to comment Share on other sites More sharing options...
Gun40t Member 98 Member For: 6y 7m 27d Posted 24/04/18 12:21 PM Author Share Posted 24/04/18 12:21 PM Yes the did to replace the gasket... about 2 months ago. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 24/04/18 12:36 PM Share Posted 24/04/18 12:36 PM So when it leaked you should have taken it straight back and told them... Link to comment Share on other sites More sharing options...
Gun40t Member 98 Member For: 6y 7m 27d Posted 24/04/18 03:02 PM Author Share Posted 24/04/18 03:02 PM I wish it was that easy mate the shop was in sydney, im on the central coast I run a buisness and a dad, I dont have time for this sh*t. Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 2d Posted 24/04/18 07:33 PM Share Posted 24/04/18 07:33 PM See if you can find a mobile thread repair ( there will be one all the workshops know of someone) He will come out & helicoil the bolt holes or you can go to repco or bursons & buy a kit & do it your self. The kit will come the right drill bit, the coils & the spanner. I don't know about changing the cam caps, aren't they supposed to be align honed? (but if you gotta do what you gotta do...) 2 Link to comment Share on other sites More sharing options...
Gun40t Member 98 Member For: 6y 7m 27d Posted 25/04/18 03:12 AM Author Share Posted 25/04/18 03:12 AM Cheers for the reply I also thought they were aligned from factory if I was to change them id have to use a plastagauge to measure the 300s of a mm to get it competly even. Link to comment Share on other sites More sharing options...
eff xr6t Member 569 Member For: 10y 5m 27d Posted 25/04/18 03:37 AM Share Posted 25/04/18 03:37 AM This^ helicoil them it'll be stronger then the original thread into the aluminium. Changing caps is not a good idea. Link to comment Share on other sites More sharing options...
