El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 28/04/18 10:10 AM Author Share Posted 28/04/18 10:10 AM Yeah I fully compressed it to test before fitting and it was all good. Problem is of course you can't actually confirm that once it's in the tank.Ultimately I'd prefer a more conventional setup, but waiting for some corrugated hose to come in the post isn't going to get me to work on Monday. Swapping the hose out sometime would be a comparatively quick job.I don't really like the approach of cutting the hose to length as a straight piece. Seems to me it would be a very fine margin between the pump sitting too high (hose too short) to or the hose kinking (hose too long). Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 9y 12d Posted 28/04/18 11:48 AM Share Posted 28/04/18 11:48 AM You can buy the 255 walbro in a direct replacement kit which jet pictured. Take out the stock pot and pump, install the new high flow pot and pump. Job done. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 28/04/18 12:21 PM Share Posted 28/04/18 12:21 PM Straight drop-in, I reckon steer clear of the big high pods,. No spastic hoses. Modified return. https://www.ebay.com.au/itm/FORD-FALCON-BA-BF-XR6-TURBO-GT-P-XR8-FPV-WALBRO-GSS341-PERFORMANCE-FUEL-PUMP/282622931073?hash=item41cda3b081:g:5~wAAOSwOTVZmpOI 5 hours ago, El Andrew said: Spot the difference. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 28/04/18 12:33 PM Share Posted 28/04/18 12:33 PM You can measure how long the hose has to be by inserting the pot into the tank and using a ruler to check the gap when it's not depressed. I did that and it worked fine. It has to be accurate though otherwise it will kink or pull the hose. It might take a few attempts. There is no point buying a "high flow pot" assembly as you can mod a stock pot well enough and just keep the fuel level high enough. If you're going to spend money make sure to spend lots just once on something worthwhile. I have a 460 in a modded stock pot which is all you need until you do a "proper" external system. It supported over 20psi on e85. I just looked at that link above and that would be fine if you didn't already have a pump. Super easy with no stuffing around. That's my thoughts and as always there's more than one way to skin a cat. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 28/04/18 01:01 PM Share Posted 28/04/18 01:01 PM I bought that one in the link with my red car (with a 255 pump in it)... super fail because the system apparently caused a fair pressure increase that the tuner had to fix with "trade secrets" at 45min or so of work to fix it... haha Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 28/04/18 01:02 PM Author Share Posted 28/04/18 01:02 PM You can measure how long the hose has to be by inserting the pot into the tank and using a ruler to check the gap when it's not depressed. I did that and it worked fine. It has to be accurate though otherwise it will kink or pull the hose. It might take a few attempts.Thanks guys. Maybe I'll give this a try rather than buying different hose.Having said that, there's probably no real reason why my approach won't work fine now that it's in. It's not like you can see it! I'm sure I read in another thread about someone looping the hose to avoid kinks. I'll be watching my AFRs closely of course.The kits that are drop in have a Walbro pump, but look like just a cheapo cradle. I feel like I'd rather have some control over the quality of hose, etc. and so like the idea of using the stock cradle rather than paying more for something that might be a backward step in the long run. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 28/04/18 01:03 PM Share Posted 28/04/18 01:03 PM (edited) I too have 460 in modded factory pod. Not a fan of the big pod, too high for the fuel to fill over the top when the tank gets low. I also have a surge with single pierberg , but soon to be twin as 1 isn't enough on E85. Single 460 will make high 400 on 98. 6 minutes ago, k31th said: I bought that one in the link with my red car (with a 255 pump in it)... super fail because the system apparently caused a fair pressure increase that the tuner had to fix with "trade secrets" at 45min or so of work to fix it... haha Trade secret = enlarges the fuel return orifice,in the pod. Edited 28/04/18 01:04 PM by arronm Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 28/04/18 01:11 PM Share Posted 28/04/18 01:11 PM Hey if it works it works. My pc is held together with beer caps and kicks ass. Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 9y 12d Posted 28/04/18 01:12 PM Share Posted 28/04/18 01:12 PM Cradles are identical to stock cradles. Mine is exactly what is in double r's post and it has been flawless. Been running strong for over two years. I would definitely prefer something that is the same as what you remove instead of something that ya hoping won't be a problem. DIY is definitely alot cheaper though. That said the drop in pots are even more DIY. They are a real easy install once ya have the fuel line removal tools. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 28/04/18 01:20 PM Share Posted 28/04/18 01:20 PM 13 minutes ago, arronm said: Single 460 will make high 400 on 98. It'll go a sh*tload more than that. I didn't run out of fuel on e85, 22psi, gen2 gtx3582r, 6500rpm, zorst, intake etc etc. Link to comment Share on other sites More sharing options...
