Aardvark74 Member 53 Member For: 6y 25d Gender: Male Location: Perth Posted 10/04/18 11:03 AM Share Posted 10/04/18 11:03 AM Hey, Pretty new at this. I'm getting a brand new Turbo (fitted by Turbo Tech) with ceramic bearings for the 'Phoon tomorrow. Now I know the turbo is the same as the XR6 but they are set to different levels. My phoon should be 9.3 Psi. When turbo tech put the new turbo in will it be the same as the previous output at 9.3, or should I mention this to them? Thanks for any help Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 10/04/18 11:05 AM Share Posted 10/04/18 11:05 AM as long as it's the same spec, in terms of it's mechanical size and control surfaces (wastegate hole and flapper sizes) etc, then it'll produce the same boost as the electronic boost control that's the factory control system will limit it to the same boost that it had previously. It might get there faster with better bearings, but it's unlikely you'll really notice it. Link to comment Share on other sites More sharing options...
Aardvark74 Member 53 Member For: 6y 25d Gender: Male Location: Perth Posted 10/04/18 11:10 AM Author Share Posted 10/04/18 11:10 AM Yeah its the Garrett 35/40 turbo..on the invoice it said for an XR6 T but they are the same turbo etc...replacing a few things, costing me 3 grand all up so just wanted to make sure. appreciate it Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 10/04/18 11:15 AM Share Posted 10/04/18 11:15 AM Just confirm the specs with the people who provided the invoice. It should be like this -> A 1.06 A/R T3 flanged, internal gated (5 bolt), exhaust housing and a 0.5 A/R compressor housing. Compressor wheel inducer diameter: 61.4mm Compressor wheel exducer diameter: 82.0mm Turbine wheel diameter: 68.0mm Link to comment Share on other sites More sharing options...
Aardvark74 Member 53 Member For: 6y 25d Gender: Male Location: Perth Posted 10/04/18 11:16 AM Author Share Posted 10/04/18 11:16 AM Thanks...is this what the BF XR6T has also though? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 10/04/18 11:19 AM Share Posted 10/04/18 11:19 AM Yep, 100%. Make sure the wastegate actuator is moved over from the original turbo to the new one. Link to comment Share on other sites More sharing options...
Aardvark74 Member 53 Member For: 6y 25d Gender: Male Location: Perth Posted 10/04/18 11:21 AM Author Share Posted 10/04/18 11:21 AM Thanks, why is this? because of the size? 'll tell them this, thanks for the advice....They are pretty reputable but it woyldnt be the 1st time ive seen pros overlook little things, all the quotes say for XR^ T Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 10/04/18 11:24 AM Share Posted 10/04/18 11:24 AM because if you get the wrong actuator, who knows what settings it'll need in the tune to accommodate the boost it'll hold. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 22d Gender: Male Location: Perth Posted 10/04/18 11:35 AM Share Posted 10/04/18 11:35 AM I did the same thing many years ago. Brand new turbo from turbo tech in Perth. Stock for stock , you will have no issues.. Link to comment Share on other sites More sharing options...
Aardvark74 Member 53 Member For: 6y 25d Gender: Male Location: Perth Posted 10/04/18 11:36 AM Author Share Posted 10/04/18 11:36 AM shouldnt they know this? damn..this is where it gets hard Link to comment Share on other sites More sharing options...
