Box stock T. Member 1,384 Member For: 8y 11m 22d Posted 15/12/17 10:26 PM Share Posted 15/12/17 10:26 PM On 12/13/2017 at 7:30 PM, Bizkets is Drunk? said: Where's the recommended place to get ya tail shaft beefed up. Want to do a few drag runs soon and dont want 3" vent hole in the floor or petrol tank. Also whats the rough cost im looking at. In SA so even if ya have a built one for seconds ill have a look. Cheers As Jet said definitely Hardy Spicer's. They cut and shut and installed and new yoke on my 351 ci XY ute years ago, top quality work and fast turn around. Reasonable price for the work performed as well. That was many moons ago and from the sounds of it there still doing top quality work. They do alot of work for Hitachi construction machinery which my mate works for and he rates them highly as well. 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 5d Gender: Male Location: Perth Posted 16/12/17 02:39 AM Share Posted 16/12/17 02:39 AM Mazda, What you had done is FDE's base spec. Phil generally quotes them good for 800hp. He will also do similar specs to what jet is talking about and the price goes up accordingly. Many moons ago /thurple ute auto to manual conversion time) I had my driveshaft shortened by VEEM here in Perth. They are known locally as Very Expensive Engineering Mistakes. Drove the car home on the high at 110kmh and parked it. Moved it the next day to wash it and found a centre cv bolt sitting in the carport. Jacked it up and found the remaining 5 all loose. #q&apeopleq&a Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 16/12/17 02:42 AM Share Posted 16/12/17 02:42 AM Phil has got a good rep in Perth. As Ralph said, he will build to what you require. Just tell him the power and how you drive. 1 Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 6m 5d Gender: Male Posted 16/12/17 06:43 AM Share Posted 16/12/17 06:43 AM On Tuesday my carbon fiber tail shaft will arrive from the states. Direct bolt in and rated to 1500hp I’ll post up some pics of this one piece unit when it arrives. Cost me $2250 delivered and should weigh half as much as any 2 piece Hardy can build. 3 Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 10y 7m 23d Gender: Male Location: Adelaide Posted 16/12/17 07:20 AM Author Share Posted 16/12/17 07:20 AM Look forward to seeing how it goes. Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 8y 11m 22d Posted 16/12/17 11:25 PM Share Posted 16/12/17 11:25 PM There ya go buddy, two options ya have now. Regency park Hardy Spicer for $2000 built with the options to return it if any problems should arise. Or carbon fibre which weighs alot less for a couple hundred more. Decisions Decisions. Definitely worth seeing how Typhoon gets on with his, if its all good, might be a good option. I'd be sticking with local. Atleast if ya get it home and ya go "hang on a second" you can run it back to them. Stranger things have happened in the world car tinkering...... 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 3m 27d Gender: Male Location: WA, Perth Posted 19/12/17 03:04 AM Share Posted 19/12/17 03:04 AM On 12/15/2017 at 2:34 PM, JETURBO said: That’s the problem @masda74 apples aren’t always apples when comparing products and prices sounds like you just got a re tube/sleeve which is common As far as I am aware, they cut the old tube out at the ends and put new ones in, along with a new center bearing. On 12/16/2017 at 10:39 AM, Ralph Wiggum said: Mazda, What you had done is FDE's base spec. Phil generally quotes them good for 800hp. I had called Phil up before hand and advised how much power my car was making and he said all good. the upgrade will handle it well. I didn't ask what they were rated at, I was just worried that the factory driveshaft would let go and rip through my fuel line and brake lines. Yes that would be a good opportunity to redo the fuel system, but not at this time of the year. I had to opportunity to get it done now and I took it up. I can sleep at night now without having nightmares. I am glad that I did not go with VEEM. I went with Final Drive as that is what everyone recommended in the past. @Typhoon good luck with the new tailshaft. Hope it fits. Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 6m 5d Gender: Male Posted 20/12/17 07:23 AM Share Posted 20/12/17 07:23 AM The shafts arrived and I've installed it. Pretty impressive! I'll post some pics shortly. View the whole album here with some descriptions-> https://imgur.com/a/bNAfn 5 Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 10y 7m 23d Gender: Male Location: Adelaide Posted 20/12/17 10:00 AM Author Share Posted 20/12/17 10:00 AM Will not let me load pics. But first it looks shorter? Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 6m 5d Gender: Male Posted 20/12/17 10:14 AM Share Posted 20/12/17 10:14 AM Bolts in without any problems at all. No clearance issues, no vibrations, no problems. Car is very smooth to drive and surprisingly faster. Very noticeable increase in acceleration, especially in the top end. It came in at 2kg lighter then the OEM setup, so it must be many kg lighter then a Hardy two piece. 2Kg lighter is not doing this shaft justice, its the balance and the smoothness that you just can't explain. The car is significantly faster! When the tyres hook up after wheel spin you feel this sling shot effect, almost like a spring has been released in the drive line. From all the modification I have done to my car up to now this is by far the most impressive. Happy to answer any question. 2 Link to comment Share on other sites More sharing options...
