Dreaded misfire issues (sigh)
XR6TTUB
  • Member For: 6y 7m 13d
Hello all and good evening
ever since purchasing this car, I’ve been trying to fix this one and only annoying hinderence
Car details ... 03 March ba xr6 turbo Ute with 5 speed manual
symptom..
cold start: starts normally and smooth (no miss or abnormal behaviour)
as as the temperature needle starts to climb, she starts to misfire,more hotter or longer I drive it, it gets more irregular.
Alao sometimes, whilst idling and misfiring away, she would stumble,revs drop and pick up again
now, I’ve Done numerous test on the vehicle and it all seems to be within factory/workshop manual specifications
oil pressure - 60psi cold and 50-60 warm
new coils and plugs
new fuel reg
new fuel filter
new throttle body and updated TPS
another set of known working injectors
all new baskets around (hot and cold side)
im a mechanic by trade, so this issue has me stumped. I’ve been diagnosing this issue for the last 2 months, but I can’t seem to replicate or trigger a change whilst doing so
on my scan tool with live data, it seems to pull timing at idle and below is some data to look into
 VCTADV(VCT ADVANCE ERROR  -9.13
VCTADV2(VARIABLE CAM TIMING 2 ADVANCE ERROR) -9.63
VCTADVERR(VCT ADVANCE ERROR) -0.69
VCTADVERR2(VARIABLE CAM TIMING 2 ADVANCE ERROR) 0
VCTDC(VARIABLE CAMSHAFT TIMING DUTY CYCLE) 0
VCTDC2(VARIABLE CAMSHAFT TIMING 2 DUTY CYCLE) 0
hope someone can shed some light,
also as a sidenote, car rev thru rev range smoothly (no misfire)
ecu previously look like someone has tampered with it and the numbers on the side of PCM have been changed
as I googled the numbers and came up with a F6 typhoon PCM
kenny
  • Puff
  • Member For: 9y 2m 18d
The earlier models have a different cam timing system than the later models.
If it has got a different ecu then it could be telling it to do stuff it shouldn't be or vice versa.
  • Member For: 7y 11m 29d
Did u happen to throw a new 02 sensor in?
Mite be dyno time though tbh, or off to ford to clear the file and reload the stock BA one in.
Go dyno though, power gains :buttrock:though that 5sp mite die after a power gain.
Thanks for the quick responses ladies and gents
o2 sensor is still the old one, haven’t replaced it yet as the values don’t go over or under reccomended values
ive Rescently replaced the cams with some later model bf cams as I had the dreaded ticking and tapping noise on cold start. Sorted that problem out though
so when I was changing the cams, I lined up all the coloured links on the chain to designated marks on cam and balancer, seems everything is spot on, and the guides are intact and undamaged
one quick observation though, with everything lined up hunky doory, the 2 marks stamped on cam phasers sit slightly off middle at 11 o’clock, cause if it did jump a tooth or 2 none of the coloured links would of lined up
like I previously stated, sometimes car would idle fine, no hiccups. 4/10 times she would idle with a miss.
dyno tuning is in process, currently getting all the bits I need before I send it off (valvesprings,injectors and fuel pump)
kenny
Another thing before I forget.
I had access to some vct solenoids and thought why not throw them in and see if it makes any difference
I had one issue with them, one on the engine seemed thinner without any filter screens and ones I had to replace them with are thicker and has filter screens
