COR24T New Member 5 Member For: 10y 4d Posted 27/11/17 11:50 PM Share Posted 27/11/17 11:50 PM I've swapped a complete sedan turbo engine, loom and ecu into a standard ute and have a problem with an airbag light. After investigation with an IDS, its been recommended to put a resistor in somewhere on the side curtain airbag to increase resistance due to not having enough or something. I've done this before on other vehicles in the UK but really want someone who knows what they're doing to complete this stage of work. Has anyone every swapped a turbo sedan engine, loom and ecu into a ute done this before or can anyone recommend anyone please? I'ts been almost 2 years and I can't find anyone who has had to go through this yet. I'm almost at the point of putting it back to standard to get it re registered and then swap it back later but I want to do it right. Thanks heaps for any advice you can give me. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 27/11/17 11:54 PM Share Posted 27/11/17 11:54 PM well, an IDS/WDS will give you all of the information required (in theory). Any auto-elec should be able to fool the system to tell it that it has an airbag when it actually doesn't, if that's what the system is looking for. Good luck 1 Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 29d Posted 28/11/17 06:35 AM Share Posted 28/11/17 06:35 AM Ba/Bf poverty packs had a resistor under the drivers seat to let the bcm think that there was a airbag there so I'd recon it wouldn't be to hard to adapt that 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 28/11/17 06:37 AM Share Posted 28/11/17 06:37 AM Any idea how many ohms it is? Mebbe my car has one but it's too hot to go outside to check atm. 1 Link to comment Share on other sites More sharing options...
