XR6TTUB New Member 20 Member For: 6y 7m 21d Posted 23/09/17 11:29 PM Author Share Posted 23/09/17 11:29 PM Gday all! Here is another video I took early morning yesterday, In this video the ticking,tapping noise is VERY evident My theory to this noise ATM is Camshaft worn (pitted and spalled camshaft lobes) worse only @ 5-6 cylinders Might try and find some standard XR6T items and investigate more Bottom end is quiet hot or cold, Only the cylinder produces the noises (using a doctors type stethoscope and electronic ear) Kenny https://youtu.be/mgXM6V3WNyg Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 9d Posted 25/09/17 01:49 AM Share Posted 25/09/17 01:49 AM Sounds like injector noise when you went to the intake side of the car. Perfectly normal if it is. Hard to really tell via a video. If you are that worried get it to your local mechanic and give it a once over but in all honesty cant hear anything sinister via the vids Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 1d Gender: Male Location: Perth Posted 25/09/17 11:35 PM Share Posted 25/09/17 11:35 PM ^whs. First vid sounds like a whole lot of exhaust leaks, second sounds like a whole lot of normal. Link to comment Share on other sites More sharing options...
XR6TTUB New Member 20 Member For: 6y 7m 21d Posted 18/10/17 09:22 AM Author Share Posted 18/10/17 09:22 AM Alrighty!! Just a quick update for everyone and anyone who is curious what the issue was. I went and purchased another set of camshafts (later model BF-FG camshafts) and measure the lobes (peaks of lobes etc) This made it very evident that the pitting and spalling of cams are signs of bad wear, causing the lobes to "flatten" So, conclusion is, if the engine has top end knock It'll be the worn cams or bad roller lifters (in my case camshafts were bad) all power is restored! and I don't have the annoying misfire at idle anymore!!! thanks to all that have replied and tried to help, Very Much Appreciated! Kenny Link to comment Share on other sites More sharing options...
