blacktur8oute Member 139 Member For: 10y 4m 23d Gender: Male Posted 04/09/17 01:48 AM Share Posted 04/09/17 01:48 AM Hi all fg xr6t won't boost it revs to about 4000rpm and won't rev any more and then when I back off I hear a gush of air coming out, it was tuned about a year ago on 98 and E85 ran perfect up until few weeks ago has the following mods 6235 precision turbosmart accuator twin 460 walbro's in PW serge PW fuel rail turbosmart reg ID 1000 injectors PW race box & cooler 4 Inch xforce ive done a bit of research on here and tried a number of things with no luck, I've repealed & checked all 6 coils replaced new genuine plugs gapped at .8 boost solenoid replaced ive checked all plumbing joins and hoses all good I removed the dump pipe to see if the flapper is moving freely with blowing air in the accuator and all good replaced fuel filter with all of the above still no luck is there any suggestions on what it could be or what else to check for before I take it to the tuner Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 15y 11m 7d Gender: Male Location: adelaide hills- 'race air' central Posted 04/09/17 02:02 AM Share Posted 04/09/17 02:02 AM (edited) cooler hoses, but you already did that. I would take a visit to your tuner before any thing else. Edited 04/09/17 02:03 AM by Panda Eyes Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m Gender: Male Location: Perth Posted 04/09/17 04:58 AM Share Posted 04/09/17 04:58 AM Are you missing any rubber gloves? 4 Link to comment Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 10y 4m 23d Gender: Male Posted 05/09/17 02:07 AM Author Share Posted 05/09/17 02:07 AM Rubber gloves ? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 05/09/17 02:29 AM Share Posted 05/09/17 02:29 AM it's a joke reference to this thread Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 28d Posted 05/09/17 03:38 AM Share Posted 05/09/17 03:38 AM Undo the outlet pipe from the turbo. find a old inner tube & cut out the valve stem with enough of the rubber to clamp around the outlet pipe, put your compressor on to the valve stem & presurize the inter cooler & piping system ( I use about 30 psi) & listen for air leaks It should hold most of the pressure If it pass's this test look at the turbo. Link to comment Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 10y 4m 23d Gender: Male Posted 05/09/17 06:27 AM Author Share Posted 05/09/17 06:27 AM Thanks will try it What's to check on the turbo both vacuum lines from the boost solinoid to the turbo and accuator are good no play in the turbo all tight it's done about 2000km Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 28d Posted 05/09/17 08:38 AM Share Posted 05/09/17 08:38 AM The actuator should hold the waste gate shut, assuming it's a 12 psi actuator it should take 12 psi down the vac hose to force the waste gate open bypassing the exhaust gas from the turbine & therefore stopping the turbine from spinning fast enough to make decent boost. Check that the actuator is fully up (you might have to measure another one) to check weather the waste gate is shut. If you unbolt the dump pipe you can see in there. But my bet its the rubber hose on the t/body Link to comment Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 10y 4m 23d Gender: Male Posted 08/09/17 01:17 AM Author Share Posted 08/09/17 01:17 AM It's not the throttle body hose I'm running a silicon one, I've pressureised the plumbing as you said holds pressure, I removed the dump pipe again and the gate was closed I put 12psi as you said and it was opening and closing freely Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 08/09/17 01:50 AM Share Posted 08/09/17 01:50 AM On 04/09/2017 at 11:18 AM, blacktur8oute said: it revs to about 4000rpm and won't rev any more Open wastegates and busted intake fittings won't cause this. A turbo car can still rev to the limiter with a huge hole in the piping and can still make boost with an open wastegate although it wont make any until about 3k to 4k rpm. At any rate the car will need to be plugged into a scanner/tuner and checked to see what is happening. Link to comment Share on other sites More sharing options...
